Type R piston Question!
Old Aug 1, 2008 | 05:26 AM
g0tgot's Avatar
Default Type R piston Question!
Will a type R piston be stamped 'P73" or anything like that. and will it fit on a gsr crank? is it just a straight swap out? or do i need to do any modifications>?
I searched for : pistons, P73, Type R piston, and i got no results....
Old Aug 1, 2008 | 06:50 AM
Rickdrizzle's Avatar
yes, it'll fit with no problems onto the gsr rod and crank or whatever.
Old Aug 2, 2008 | 04:47 AM
g0tgot's Avatar
k someone tried to sell me soe pistons that had no stamp on them sayng they were ITR pistons, but they were flat with no stamp.....so i think they were BSing me.....thanks for the info!
Old Aug 2, 2008 | 05:57 AM
hpimichael02's Avatar
probl;y dumb questiuon but thought id ask, if i were to gtet new rods and pistons would the ITR ones fit in the LS/GS/RS engine B18b1?? would that pose a probloem cause it lacks vtec?
Old Aug 2, 2008 | 01:49 PM
Kendall's Avatar
You'll either see P73 A01 or you'll see P73 001 on the top of the piston. There will be a noticeable dome as well.
Old Aug 2, 2008 | 06:48 PM
JDMThoughts's Avatar
From: Standing on the corner selling cocaine, rippin shows live on stage for hoes yellin my name
Default Re: (Kendall)
Don't waste your time on ITR rods. If your going to do a build, figure out what your trying to achieve before you buy the wrong parts. Most builds can be fashioned with Eagles or some other equivalent. you should go with a set of overbored pistons, so you can get a fresh bore and hone. They sell oversized JDM ITR pistons all over the place. If you drop in a set of JDM ITR pistons your compression should be in the mid 11.6 range. Which is plenty fine for daily driving on premium pump gas.
Old Aug 4, 2008 | 11:59 PM
DaJeremy's Avatar
if your going for higher compression i would use the jdm p30 pistons they'll probably be cheaper too.
Old Aug 5, 2008 | 07:16 AM
ruffrhyder's Avatar
Default Re: (DaJeremy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaJeremy &raquo;</TD></TR><TR><TD CLASS="quote">if your going for higher compression i would use the jdm p30 pistons they'll probably be cheaper too.</TD></TR></TABLE>
Show me where you can get p30 for less than $160 shipped with rings and wrist pins. Also, do you even know what the OP's CR goal is? Do you know what CR P30's in his build would yield, we don't even know what head the OP is using, if its been milled, if the block is decked, etc.
dunked dc
Sep 26, 2010 02:58 PM
bluedlude
Dec 15, 2007 09:26 AM
Slow Ek
Aug 6, 2007 07:27 PM
EARLdaSQUIRREL
Apr 9, 2003 12:09 PM
H22ek4
Feb 3, 2003 08:09 PM
