d16 jackson racing supercharger on d15b vtec
anyone here knows if a d16 JRSC fit on the jdm d15b vtec? since its pulleys and belts are all diff from usdm. also dont know about the intake manifold bolt pattern is the same as usdm d16
intake manifold bolt pattern is the same, as is everythign else. the kit has tension adjustments so if the pulley is a slightly diff diameter it wont really matter. Ive mixed macthed rib numbers as well.
For example 4 rib JRSC with 3 rib alt/crank pulley
I had that exact setup, The pullys don't line up, You will have to call jackson racing and get the right supercharger pully for it to line up.
Thanks I had to ask that question because the guy thats buying it doesnt know and so do i either but thanks for the info.
ty521825
Dec 23, 2010 07:34 PM
ty521825
Dec 23, 2010 07:33 PM
b18, d15, d15b, d16, dseries, honda, installation, jackson, jrsc, racing, road, series, supercahrger, supercharge, supercharger, superchargers
