Oil Leak 1990 Integra
I have a 1990 Integra with an oil leak by one of the cams. Here's a picture of where it is comming from. I wiped it off a little while before I took the pic but highlighted it. The engine is a b18a1. The car is all stock i think. [IMG][http://img112.imageshack.us/img112/6...75yq0.jpg/IMG]
http://www.inlinefour.com/bilalcamplug.html
one of those doo, its common and a easy fix if you dont mind taking off your valve cover. The seals went bad
i just did mine 2day blox cam seal..take it easy on the bolts tho i broke 2 of 4 turned out to be a few hour project but i got it done...u gotta take the vavecover off and take off 4 bolts 2 are shown in the pics and 2 are under the valve cover
yea - only 7.2 ft/lbs on those cam retainer bolts. I broke one too the first time I did it.
Also 7.2 on the valve cover nuts. If you've never had the valve cover off, then you'll want/need to replace the valve cover gasket and the spark plug o-rings as well.
And get some Hondabond while you're at it - you'll need that too.
PhunekyPhish
18
May 13, 2014 02:47 AM
NiBlazed
Dec 19, 2004 08:33 AM
