cold air intake install
93 prelude si 2.3L
yes i am an amateur and have a question about installing my cold air intake
i took off the intake control diaphragm and housing(resonator?) in order to fit my new cold air intake
the intake control diaphragm has a line running up to the intake control solenoid
so my question is, do i just discard the intake control diaphragm and housing (resonator) and cap off that line that runs to the intake control solenoid?
thanks!
Modified by deercanbrack at 8:10 PM 7/31/2008
Modified by deercanbrack at 8:14 PM 7/31/2008
thanks!
Ok nevermind, I found a site that went over all that.
For anyone else who had the same dumb question...
http://www.alldatapro.com/alld...37783
You can remove the resonator and just tie off or plug that vacuum line that plugs into the butterfly valve that is on the resonator.
Also, check this website out, it goes over the entire intake install...
http://www.ntpog.org/mods/fift...shtml
