Replaced tie rods and atts fluid- now no start
Old Jul 31, 2008 | 04:44 PM
vinuneuro's Avatar
Default Replaced tie rods and atts fluid- now no start
I replaced the outer tie rod ends and atts fluid yesterday. Finished up the work and started the car. It started and ran poorly, sputtered off within 5 sec. It won't start at all now.
Got fuel- fuel pump priming, and injectors getting signal.
Got spark
Timing is perfect
No cel codes
I tested the coil for the hell of it. The primary winding resistance spec is .64-.78ohm. My multimeter got .4(no hundredth place).
Can the coil be bad despite producing spark?
Any other sensors that can cause something like this? ckp? The engine did start, but then sputtered off, so it makes me think the problem is more fundamental (fuel, spark, etc. Any ideas?
MastaFlyMason
May 18, 2013 09:32 AM
help97acura
Sep 17, 2012 06:19 PM
chbek9
Jul 5, 2011 07:34 PM
vinuneuro
Aug 1, 2008 10:36 AM
gabhatch
Jun 22, 2008 07:22 PM
