Replaced tie rods and atts fluid- now no start
Old Jul 31, 2008 | 04:19 PM
vinuneuro's Avatar
Default Replaced tie rods and atts fluid- now no start
So all I did was replace the outer tie rod ends and atts fluid. Finished up the work and started the car. It started and ran poorly, sputtered off within 5 sec. It won't start at all now.
Got fuel- fuel pump priming, and injectors getting signal.
Got spark
Timing is perfect
Any ideas?
Old Jul 31, 2008 | 04:23 PM
gstrudler's Avatar
Default Re: Replaced tie rods and atts fluid- now no start (vinuneuro)
Any CEL's you can pull? Only thing I can think of is if somehow you knocked a wire or sensor loose while you were down around the ATTS unit.
Old Jul 31, 2008 | 04:36 PM
vinuneuro's Avatar
Default Re: Replaced tie rods and atts fluid- now no start (gstrudler)
No cel's. I can't imagine what sensor what cause the car to not start. It did start, but then sputtered off.
Old Jul 31, 2008 | 06:59 PM
TruNinja619's Avatar
do you see the Immobilzier key blinking when you try to start your car?
Old Jul 31, 2008 | 07:26 PM
vinuneuro's Avatar
Default Re: Replaced tie rods and atts fluid- now no start (TruNinja619)
Immobilizer light turns off after two seconds like it should. It's not that.
Can the coil be bad, and still produce spark. The helms resistance says that the range should be .64-.78ohm. I'm getting .4.
Old Jul 31, 2008 | 09:00 PM
lude98SH's Avatar
thats on the primary side of the coil right ? are the secondary windings within spec also ?
A friend on mine(acura integra) just had a coil that was about 1kohms low on the secondary. The car just died on him while driving and wouldnt restart. When we checked the resistance we at first werent sure if that would be it because the spec was like 12k -15ohms and we were at like 11k or something. And it turned out to be the coil that fixed it, runs perfect now.
Old Aug 1, 2008 | 10:36 AM
vinuneuro's Avatar
Default Re: Replaced tie rods and atts fluid- now no start (lude98SH)
Secondary resistance is right in the middle of spec. Primary resistance is the one that's low.
vizsual00
Mar 20, 2005 01:49 PM
rhl487
Sep 17, 2004 11:53 PM
rasta420
10
Jul 31, 2004 10:50 PM
Accord15
Jun 25, 2003 09:54 AM
