help!! engine bolt broken
how much is it gonna cost me to fix it???
do yall think this is something serious??
http://s47.photobucket.com/alb...7.jpg
http://s47.photobucket.com/alb...0.jpg
http://s47.photobucket.com/alb...9.jpg
Modified by 5800vtec at 5:30 PM 7/31/2008
#9 is $1.82
http://www.hondaautomotivepart...COVER
Edit:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteOnRice »</TD></TR><TR><TD CLASS="quote"> Take the coil cover off and you'll see the bolt that broke has a 10mm head on it (#9 on above pic). Use a 10mm deep socket and you're good to go.</TD></TR></TABLE>
Edit: Make sure you torque those bad boys down to 7.2 Ft-lbs.
That is very little. Like snug. About 1/2 the torque required for a sparkplug (13 Ft-lbs)
Modified by _BEN_ at 5:35 PM 7/31/2008
Modified by _BEN_ at 6:54 PM 7/31/2008
Not really. It looks like it broke off where there is still some sticking out so you can grab it with vice grips.
I would still fix it. I'm nit picky but it would not keep me up at night or leave me stranded.
It is not uncommon for those the brake. They commonly get corroded and/or get over tightened.
If you search "broke valve cover bolt" you will get a bunch of hits.
He doesn't have to do anything with the valve cover. Take the coil cover off and you'll see the bolt that broke has a 10mm head on it (#9 on above pic). Use a 10mm deep socket and you're good to go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteOnRice »</TD></TR><TR><TD CLASS="quote">He doesn't have to do anything with the valve cover. Take the coil cover off and you'll see the bolt that broke has a 10mm head on it (#9 on above pic). Use a 10mm deep socket and you're good to go.</TD></TR></TABLE>
That's correct.
I was having a B series flash back.
lol
That's correct. I was having a B series flash back.
lol
