5th gen shock knock even with teins
Old Jul 31, 2008 | 04:00 PM
wle05's Avatar
Default 5th gen shock knock even with teins
Anyone with coilovers are you still having any noise coming from you rear end? Ive installed tein flex coilovers and it still sounds like i have shock knock. Before i installed the teins i had sprint springs and stock shocks I even did the updated collars that were on the service bulletin and still had noise from the rear. Its really annoying so just asking any prelude owners for opinions or comments.
Old Aug 1, 2008 | 08:19 AM
wle05's Avatar
Default Re: 5th gen shock knock even with teins (wle05)
bump...... any one
Old Aug 2, 2008 | 07:11 AM
bb6_00's Avatar
yea, i have tein basics and the rear sounds like that sometimes, checked if anything is loose and nothing. Shock is almost new so it shouldnt be blown.
.........BUMP
Old Aug 2, 2008 | 07:21 AM
91lude4ws's Avatar
i have kyb gr2's with tein s-tech springs in the rear and i always get shock knock off my right rear. i think the strut is on its way to going out but i've heard about it simply being a problem with the seating of the spring.
Old Aug 2, 2008 | 08:29 AM
roost 'er's Avatar
You sure its not something like a sway bar bushing, if they wear out the sway bar will hit the mount where the solid rubber should be thus creating a knock, seeing as you have interchanged shocks and still had the problem id almost entirely rule shocks out.
Old Aug 2, 2008 | 12:23 PM
wle05's Avatar
Default Re: (roost 'er)
thanks im going to have to check that out car only has 46000 miles so im not sure wth is goin on. car sat for a year until last month then i threw teins on it. I will be checking the sway bar bushings to check. thanks for the info keep it coming
siggy833
Acura TSX
Sep 17, 2007 06:00 AM
jmai86
Mar 30, 2007 01:30 AM
satsilprelude
Mar 17, 2006 12:52 PM
moemoe
Dec 7, 2005 08:39 AM
ckyguy
Suspension & Brakes
Aug 19, 2005 09:24 AM
