Just got my 91 Honda CRX Si back, Need some help.
Old Jul 31, 2008 | 01:07 PM
meandino's Avatar
Default Just got my 91 Honda CRX Si back, Need some help.
I just bought back my 91 Honda CRX Si. Its Black on Black and has 259,000 miles. Doesn't look like it has that kind of mileage. No Rust or body work has been done to this at all. Has the Stock D16A6 motor. Skunk 2 Coil Overs on Tokico Blue shocks. Front drilled rotors. Painted Red calipers. 17" ADR Sukodo gunmetal wheels. Grant steering wheel. Aftermarket shift ****. Black Housing Halo headlights that don't even work. The whole interior is there and clean. Paint is in good shape with clear coat coming off on hood and sunroof only.
I sold this car to a friend of mine back in April of 2007. I was the third owner with the second owner having it for 3 months only. My friend drove the car for 2,000 miles within the past year and couple months. He bought a Mustang is the reason.
Anyways the car sat there for some time just building up dust. He did not take very good care of the car and therefore needs a lot of work. So I need your help to figure out some problems on the car. Here is what I have done so far:
Took the alarm out since he lost the keypad.
Striped the interior and cleaned everything.
Cleaned the engine bay.
Replaced the Headlights with stock ones.
Switch out the steering wheel with a stock one.
Took off the shift ****.
Changed spark plugs.
I'm needing to get another radiator for the car as he put a '90 Acura Integra radiator in it to fix the leak it had. I'm going to go to the dealership for this part.
I need hep with the sunroof as its not working at the time but did at one point.
I'm trying to get the kinks worked out with the engine.
Help me out H-T. Need to get this thing running correctly.
Modified by meandino at 9:35 PM 8/1/2008
Old Jul 31, 2008 | 01:15 PM
_Keith_'s Avatar
Check your grounds. Essepically the one coming off the batery.
Old Jul 31, 2008 | 01:22 PM
meandino's Avatar
Default Re: (_Keith_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _Keith_ &raquo;</TD></TR><TR><TD CLASS="quote">Check your grounds. Essepically the one coming off the batery.</TD></TR></TABLE>
Great sugestion. The one coming off the battery was in the wrong location. It was connected under the battery tray not the chassis. Will give you update when I put it back to original spot.
Old Jul 31, 2008 | 01:32 PM
D16SiHatch's Avatar
Default Re: (meandino)
sounds like you could use some new plug wires. Also check the voltage at your battery with a multimeter and see if the alternator is putting out a decent amount of voltage.
Old Jul 31, 2008 | 01:35 PM
meandino's Avatar
Default Re: (D16SiHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16SiHatch &raquo;</TD></TR><TR><TD CLASS="quote">sounds like you could use some new plug wires. Also check the voltage at your battery with a multimeter and see if the alternator is putting out a decent amount of voltage.</TD></TR></TABLE>
Yes I do need new plug wires. Need a new Radiator as well. He had one in from a DA Integra. The hood won't shut. I will be putting in a big order with Honda here really soon.
Old Jul 31, 2008 | 01:58 PM
meandino's Avatar
Thanks to _Keith_ For the suggestion of checking the ground cables. The battery ground cable and the Engine ground cable both needed to be hooked up. Now the engine starts with no hesitation.
Now the Tach is not showing any RPM and I don't think the gas gage is working. How do you Diagnose the Tach?
Old Jul 31, 2008 | 02:06 PM
meandino's Avatar
Pictures are up.
Old Jul 31, 2008 | 02:42 PM
zrickety's Avatar
my b16 had similar symptoms...turns out the guy that sold me the car had cracked a piston. i also found a loose injector wire in the same spot.
Old Jul 31, 2008 | 02:43 PM
meandino's Avatar
Default Re: (zrickety)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zrickety &raquo;</TD></TR><TR><TD CLASS="quote">my b16 had similar symptoms...turns out the guy that sold me the car had cracked a piston. i also found a loose injector wire in the same spot. </TD></TR></TABLE>
Did he not tell you about these before you bought it?
Old Aug 1, 2008 | 12:24 PM
meandino's Avatar
How do I fix my sunroof?
It opens just fine but does not close. You can hear it trying though. I jump the relay and it shut. So I replaced it and now nothing. Doesn't open or shut.
How do I fix this problem or diagnose it better?
Old Aug 1, 2008 | 12:33 PM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
Search for sunroof threads. Post if not found.
Old Aug 1, 2008 | 12:53 PM
meandino's Avatar
Default Re: (phoenix_iii)
Old Aug 1, 2008 | 07:46 PM
meandino's Avatar
Changed out the spark plugs and got it running really good.
Still need info on the sunroof. Been using the search with no luck yet. Help me out here.
Old Aug 1, 2008 | 07:54 PM
Slystone's Avatar
one day a buy a CRX SI that the sunroof did't work.....it was the relay close to the fuse box was totaly burn out!
Old Aug 1, 2008 | 08:04 PM
meandino's Avatar
Default Re: (Slystone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slystone &raquo;</TD></TR><TR><TD CLASS="quote">one day a buy a CRX SI that the sunroof did't work.....it was the relay close to the fuse box was totaly burn out! </TD></TR></TABLE>
Thing is I bought another relay off a H-T member and I'm getting the same results.
Old Aug 1, 2008 | 08:57 PM
meandino's Avatar
If someone wants the Black housing halo's you can have them for free you just pay for shipping.
PS. Halo's don't work.
Old Aug 1, 2008 | 09:35 PM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meandino &raquo;</TD></TR><TR><TD CLASS="quote">How do I fix my sunroof?
How do I fix this problem or diagnose it better?</TD></TR></TABLE>
For bringing her back to 100% stock. Unmolested CRX's are an endangered species.
The cable and rails need to be lubed, you can do it the easy-ghetto way like I did, Or the way the Helms tells you. And perhaps your sunroof switch need de-oxing.
Old Aug 1, 2008 | 11:14 PM
meandino's Avatar
Default Re: (4crx4me)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4crx4me &raquo;</TD></TR><TR><TD CLASS="quote">The cable and rails need to be lubed, you can do it the easy-ghetto way like I did, Or the way the Helms tells you.</TD></TR></TABLE>
It doesn't need any lube as it opens and shuts just fine. Its more in the wiring, switch or relay.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4crx4me &raquo;</TD></TR><TR><TD CLASS="quote"> And perhaps your sunroof switch need de-oxing. </TD></TR></TABLE>
Explain.
Old Aug 1, 2008 | 11:37 PM
meandino's Avatar
Ok my gauges don't work either. I'm not getting any RPM's in the tach. what should I be looking for?
Old Aug 2, 2008 | 01:17 AM
Maldito X's Avatar
I forgot to tell you this while I was at your house, sorry lol....but.....
Take off your distributor, remove the cap, and check the 3 or maybe it's 4...wires that are hooked up next to one another, remove each one, inspect the connectors to ensure they are clean, if they came off easy then grab some pliers and kinda squeeze each one so they have a tighter fit on the prong, then put them back on.
I've had a very similar situation to what you were describing TWICE and both times I fixed it by ensuring a good connection on the wires inside the dizzy cap. It takes 5 minutes and fixed it each time.
Old Aug 2, 2008 | 04:23 AM
sixgunsound's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meandino &raquo;</TD></TR><TR><TD CLASS="quote">Ok my gauges don't work either. I'm not getting any RPM's in the tach. what should I be looking for?</TD></TR></TABLE>
Check your fuses.
Old Aug 2, 2008 | 05:34 AM
meandino's Avatar
Default Re: (Maldito X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maldito X &raquo;</TD></TR><TR><TD CLASS="quote">I forgot to tell you this while I was at your house, sorry lol....but.....
I've had a very similar situation to what you were describing TWICE and both times I fixed it by ensuring a good connection on the wires inside the dizzy cap. It takes 5 minutes and fixed it each time. </TD></TR></TABLE>
I will do that anyways just because it sounds like a great idea to do. I fixed the problem though by buying one spark plug till my others come in. I runs like a champ now and does not studder.
I toke it for a drive and when I slow down you can hear what sounds like compression really defined in the engine. Is it suppost to do that or is the engine just getting really high miles and now its showing? Any way tofix besides a rebuild?
Old Aug 2, 2008 | 05:36 AM
meandino's Avatar
Default Re: (sixgunsound)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sixgunsound &raquo;</TD></TR><TR><TD CLASS="quote">Check your fuses.</TD></TR></TABLE>
I thought that the fuse only controls the light in the instrument panel? I'm going down today to get some fuses because there are only a couple in the box. But figured it was not link directly to that.
I guess after I replace them all I'll give you an update.
Old Aug 2, 2008 | 05:39 AM
meandino's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maldito X &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
Old Aug 2, 2008 | 06:43 AM
pxsx's Avatar
yeah check the fuses.
It could be the switch. And I have a switch for you if you think it is that.
Can you still move the sunroof manually with a wrench?
The clutch on the sunroof motor could be out of adjustment too. just close the sunroof, and tighten that nut on the motor.
