ODB0 ECU Starts Car with ODB1 Ignition
I run a chipped P28 with and OBD0 to 1 conversion harness and and OBD1 ignition in my 89 CRX.
Yesterday, I wanted to test an OBD0 PR3 ECU so I removed the conversion harness, connected the PR3 and successfully started the car.
I know that you cannot use an OBD1 ECU without an OBD1 ignition because of the different crank sensors (16 vs 24 teeth) but I didn't know you could use an OBD0 ECU with an ODB1 ignition!
Just sharing just in case no one had come across this
Modified by 7rrivera7 at 9:56 PM 7/31/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7rrivera7 »</TD></TR><TR><TD CLASS="quote">I run a chipped P28 with and ODB0 to 1 conversion harness and and ODB1 ignition in my 89 CRX.
Yesterday, I wanted to test an ODB0 PR3 ECU so I removed the conversion harness, connected the PR3 and successfully started the car.
I know that you cannot use an ODB1 ECU without an ODB1 ignition because of the different crank sensors (16 vs 24 teeth) but I didn't know you could use an ODB0 ECU with an ODB1 ignition!
whats a odb i think you meant obd
</TD></TR></TABLE>whats a odb i think you meant obd
7rrivera7
Aug 12, 2008 04:51 AM
