Question about 4th & 5th gen suspension.
Old Jul 31, 2008 | 12:04 PM
socialistic's Avatar
Default Question about 4th & 5th gen suspension.
I have a 93 Si with oem struts/springs, and my buddy has a 97 with tokico struts/eibach sportline springs...and we want to swap strut/spring assemblies because he doesn't want his car lowered and I do.
Is this possible, or are there differences between the two cars that would keep us from swapping strut/spring assemblies?
Old Jul 31, 2008 | 01:03 PM
AndyD's Avatar
Default Re: Question about 4th & 5th gen suspension. (socialistic)
4th gens and 5th Gen Bases have the same suspension setup. The only difference are the strut hats.
Type SH have a different setup. I can't remember if the fronts are different or the rears. I believe the rears are different.
Old Jul 31, 2008 | 01:13 PM
Well...my '93 is an Si, and I think he has an SH.
Old Jul 31, 2008 | 01:21 PM
vinuneuro's Avatar
Default Re: (socialistic)
Only the front SH springs and shocks are different. All aftermarket stuff, both springs and shocks are designed for 4g/Base, which is why you can use them on an SH. 4g and 5g suspension are completely compatible in terms of interchangeability.
Old Jul 31, 2008 | 01:39 PM
So that means I can swap my oem 4g f & r strut assemblies with his 5g aftermarket f&r strut assemblies?
Would I have to swap tophats like that guy said in the second post?
Old Jul 31, 2008 | 01:58 PM
vinuneuro's Avatar
Yea you can swap them without a hitch. You need to use your 4g tophats.
Old Sep 23, 2009 | 08:23 PM
danewickenhauser's Avatar
I am confused. So can you take the f and r struts/springs from a 5g sh and put them onto a 4g with no problem?
racins4
May 7, 2020 07:56 PM
305PRC91
Sep 16, 2008 07:42 AM
hushbald
Jul 21, 2007 05:11 AM
Mike36
Mar 3, 2007 10:09 PM
