EP3 Shocks 50mm or 55mm
How do i know which i have. I drive an 02 ep. Can you tell by something or do you just take off the rim and it says it on the shock? Stupid question I know but thanks anyways.
An 02 is more than likely 50mm.
You could always buy some clapped-out OEM 04-05 EP3 front shocks for cheap if you can only find 55mm Konis.
04-05 Civic (all) front shocks will also work. RSX shocks will not (well, not straight bolt-on).
My ep3 which is a 03/03 production date had the 50mm front struts. Don't make the mistake I did and order the wrong ones on accident and after you have already sawed off the top the strut realize you are effed hardcore. Then you have to watch your car sit in the driveway for a week while you drive a 94 Ford Aspire in bright purple with a slipping clutch.
