Brakes Locking up. Please Help!
Whatsup honda-tech,
Having a brake problem with a 2002 accord. The brakes are locking up and it feels like the pedal is not releasing. Changed the front calipers and brake booster and brake fluid and that only sort of helped...Now when going at higher speed like on the highway trying to use the brakes causes the car to slow down really fast. It feels like the brakes are kind of "dragging" when driving and the gas pedal always needs to be pushed. Thanks for the help.
What was the reason for changing the booster?
Did you change the booster before the problem started to occur?
You do know of course, that the Master Cylinder push rod has to be adjusted correctly or the Brakes will not release pressure? Hmmmmmm?
why does the abs light come on, because my 98 accord has that dragging feeling like i always have to push the gas cause when i let off it slows down like i have the brake pushed a little bit
SpeedFreek34
Jul 22, 2007 05:43 PM
allmotorEG-SI
Dec 27, 2004 06:13 PM
