Cutting a valve cover?
Old Jul 21, 2002 | 09:26 PM
Edwin's Avatar
Default Cutting a valve cover?
Any tips on cutting a valve cover for cam gear adjustment?
Do you gut the cover and the plastic shield?
Old Jul 21, 2002 | 09:41 PM
InevitableRace's Avatar
Default Re: Cutting a valve cover? (Edwin)
why dont you adjust them once and then keep them covered.dont cut the cover it looks better anyways and no one knows you have anything...
Old Jul 21, 2002 | 09:55 PM
integRated109's Avatar
dremmel tool, like butta
Old Jul 21, 2002 | 10:27 PM
Tommy_Gunns's Avatar
Default Re: Cutting a valve cover? (integRated109)
I love my dremel. Too bad it is working like **** (loose connection somewhere) and I lost my receipt.
NOTE: To anyone who plans on buying a dremel, tape your receipt to your dremel case. They have a 5 year warrenty (I thought it was one year and through it out ).
Old Jul 21, 2002 | 10:31 PM
Edwin's Avatar
Default Re: Cutting a valve cover? (allmotrb18c1)
How do I tune (make adjustments) without having the valve cover on the car? Are you implying that everytime I make adjustments, I have to remove and put the covers back on? Or maybe you have a certain method you can recommend.
Old Jul 21, 2002 | 10:54 PM
yeah basicly keep the cover on..this is what you do....tune the car a TDC on the cams and do a pull...and see waht you have..ok take the valve cover off and the plastic cover off too and do a adjustmint on it and put only the valve cover back on and do another pull and see what you get if you dont like it then take the cover off again and do another adjustment and look at what you get and if you like it take the valve cover off again and put the plastic back on and the valve cover..and now you have adjusted the cams and it looks stock..i know it sounds like a big pain in the *** but it looks better than have you timing belt showing and safer..im me if you want to Eg6civicsi92
Old Jul 21, 2002 | 10:58 PM
mugenintegra16's Avatar
yes i wouldn't cut the cover either cause i've seen cars where stuff actually flys in there and rips apart the timing belt. Then bye bye belt. What i did was buy an extra one from a junk yard only $40 dollars use that to tune and when it was done put back the original one and cover it up.
Old Jul 22, 2002 | 06:19 PM
Edwin's Avatar
Default Re: Cutting a valve cover? (mugenintegra16)
Chop!
Old Jul 22, 2002 | 06:38 PM
Turtle's Avatar
now your going to kick yourself...(maybe not, but this is what I was thinking you were talking about doing)...
Brandon - Who is making this change sometime this w/e t
[Modified by 401-2001, 10:39 PM 7/22/2002]
Old Jul 22, 2002 | 07:40 PM
A11MotorR's Avatar
New User
Default Re: Cutting a valve cover? (401-2001)
Borrow your friends chopped valve cover for dyno. When done put yours back on.
Old Jul 22, 2002 | 10:00 PM
EagleR's Avatar
Default Re: Cutting a valve cover? (A11MotorR)
Don't do it to one that you plan on using daily....
Buy a dyn0 bitch.....
[Modified by EagleR, 2:00 AM 7/23/2002]
Old Jul 23, 2002 | 01:53 AM
ITR 99's Avatar
New User
Default Re: Cutting a valve cover? (EagleR)
seriously what r the chances of something getting in and recking the timing belt, ive seen pics on cars of the whole gears exposed
[Modified by ITR 99, 6:54 PM 7/23/2002]
Old Jul 23, 2002 | 03:08 AM
Turtle's Avatar
Default Re: Cutting a valve cover? (ITR 99)
Very minimal chance, but it really depends on how you make your cut. Obviously, the moon cut is way better (you can barely stick a peice of paper in a moon cut gap). I know people that have used a completely exposed set-up for about 1 1/2 years, and through a winter as well...nothing happend. I probably wouldn't want to do this, however it did comfort me enough to cut a moon shape into the vavle cover.
Old Jul 23, 2002 | 04:49 AM
MPH's Avatar
MPH
New User
How is he going to adjust them without a valve cover. To do it right he will need to be on a dyno and from what I seen you need a valve cover with a opening to adjust the cam gears.
[Modified by MPH, 10:01 AM 7/23/2002]
Old Jul 23, 2002 | 05:06 AM
Ex-ITR5874's Avatar
Get a b16 cover (steal it from a civic... if they steal our R`s, we can steal their valve covers)...
That`s mine:
Old Jul 23, 2002 | 05:52 AM
TsunamiZC's Avatar
Default Re: Cutting a valve cover? (ITR1858)
the moon cut rocks , i'll have mine one day...when i get cams , and cam gears
Old Jul 23, 2002 | 06:38 AM
nsx-Animal's Avatar
[QUOTE]
QUOTE]
Wow that looks nice where did you get that done?
Old Jul 23, 2002 | 07:25 AM
onyx00's Avatar
Default Re: Cutting a valve cover? (Itr-Animal)
I just run with no valve cover. I go through a lot of oil, but no biggie.
Old Jul 23, 2002 | 07:29 AM
MPH's Avatar
MPH
New User
Default Re: Cutting a valve cover? (onyx00)
Hmm, maybe I should try that. That way I can save time on valve adjustments and not use up all my honda bond
Old Jul 23, 2002 | 07:30 AM
slowerthanu's Avatar
New User
The reason I have not cut mine is because cam gears are illegal on an emmisions controlled vehicle, what they cant see they cant question, esspecially if it passes the sniffer test.
Old Jul 23, 2002 | 07:35 AM
Ex-ITR5874's Avatar
Default Re: Cutting a valve cover? (tsunami_zc)
Hmmm,
no need to buy an extra valve cover that lets you reach the screws....
Just an old and dirty b16 cover from the junkyard... You can leave it under the hood as long you are within the tuning period and when everything is done, put the stock cover on....
Old Jul 23, 2002 | 07:36 AM
reefer_bob's Avatar
Default Re: Cutting a valve cover? (slowerthanu)
Exactly! I've had cam gears on cars before, but being in Cali, gotta keep that ish covered up so the coppers don't see it when they pull you over and tell you to open your hood.
Best thing IMO is to get a friend with a chopped valve cover, tune with that and then put yours back on. I have an extra one that I'm going to cut once I get my cams and cam gears...
Old Jul 23, 2002 | 07:39 AM
AssPenny's Avatar
Default Re: Cutting a valve cover? (reefer_bob)
Picked up a GSR valve cover for 50 bux about 8 months ago. Jason used it to tune his car and now I have it sitting in my garage for when I do mine. Only time it'll be on my car is when I go to the dyno.
Old Jul 23, 2002 | 07:47 AM
TsunamiZC's Avatar
Default Re: Cutting a valve cover? (MPH)
bet that saves weight too ..LOL
Old Jul 23, 2002 | 08:37 AM
Black R's Avatar
25 Year Member
Yup. Me = almost learned the hard way.
From now on, I'll just keep the uncut cover on there and change to uncut one at the dyno. Then back to uncut as soon as I'm off the rollers.
