Megan LCA top holes? For Lube?
I bought Megan lower control arms and theres three holes above the bushings where a threaded screw can be screwed in. Are these holes used to lube the bushings? Or are they the type of bushings that dont need to be lubed?
the screw holds the bushing from spinning inside event though its sitting pretty stiff there. i guess since the lca is made of aluminum they putted there for a reason; not for lubing obviously
Thrillhouse
May 20, 2005 11:50 AM
Old91CivicGuy
Jun 18, 2001 01:55 PM
