HELP! CAN I PUT THE REAR DISC OF A DEL SOL ON MY 89 SI HATCH
Old Jul 30, 2008 | 08:35 PM
civicdust's Avatar
Default HELP! CAN I PUT THE REAR DISC OF A DEL SOL ON MY 89 SI HATCH
WILL THE HAND BREAK LINES BOLT IN PROPERLY????? HELP MEEEEEEEE
Old Jul 30, 2008 | 08:38 PM
BigDare23's Avatar
Yeah, the brake line will match up.
You can used any rear disc conversion from a DA/EF/DC/EG/EK on your hatch. For example, I'm using GSR trailing arms on my EF hatch.
Just make sure you keep your current control arms
*edit*
The parking brake line should work. Since you are installing them on a hatch rather than a CRX, you need the longer parking brake line from an integra or newer civic.
Modified by BigDare23 at 1:03 AM 7/31/2008
Modified by BigDare23 at 1:04 AM 7/31/2008
Old Jul 30, 2008 | 09:32 PM
xsirenax's Avatar
you know whats funny when you buy the disk swap for an ef its cheaper than when you buy it for an eg....i thought it was cause they were different but if youre right about it fitting the same on all those cars....those ******** >: o
GSR_ITR_BOIB
Suspension & Brakes
Jan 4, 2016 11:16 PM
CIVIC9922
May 18, 2011 03:17 PM
MPALUGHI
Jul 12, 2008 06:55 PM
Fezzie
Oct 8, 2006 08:58 PM
b16b hatch
Jan 4, 2003 12:18 PM
