1995 Civic DX Engine Idle Problem
Old Jul 30, 2008 | 06:36 PM
nosbocaj's Avatar
Default 1995 Civic DX Engine Idle Problem
I have a '95 Civic that has problems idling. It generally only happens when the car is warm, but it does seem to happen other times as well. The car seems to idle fine, but then it will miss occasionally. It was much worse, and the car would die altogether. I replaced the fuel filter, spark plugs, and wires. It got much better and almost disappeared when I put in the spark plugs, but the problem seems to have not gone away altogether. I have also tried fuel injector cleaner, and "heat" in case I got some bad gas.
One other thing I didn't mention was that it had been missing (until I replaced the spark plugs) when the car was at lower rpm going up hills, but when it would downshift so the car was using higher rpm, it wasn't a problem.
Any ideas?
Modified by nosbocaj at 7:43 PM 7/30/2008
Old Jul 30, 2008 | 07:23 PM
vtecb18c's Avatar
Default Re: 1995 Civic DX Engine Idle Problem (nosbocaj)
possibly a bad 02..try cleaning your IACV aso
daxlasaint
Nov 4, 2016 03:39 PM
safehouse3238
10
Mar 25, 2010 03:34 PM
EG6AAARRR!!!
32
Jun 19, 2007 10:57 AM
schuetts
Dec 11, 2006 08:35 PM
NightHawk
16
Apr 16, 2003 05:52 PM
