Bogging issue?
Old Jul 30, 2008 | 04:44 PM
ef-hatchcrap's Avatar
Default Bogging issue?
Well I had a code 8 I redid my dizzy harness and got all my codes to go away.
But I still have this issue with whenever I got to wide open throttle my car boggs down. I never had this problem until I converted to obd-1.
Its a 91 dx hatchback with a full y8 I/H/E clutch light weight flywheel, mount inserts and running a chipped p28.
I have heard on other sites that you cannot run a stock p28 on a y8 because it will run like ****. is this true?
do I need to go get my car tuned? any help is appreciated in advance
Old Jul 30, 2008 | 04:55 PM
nihad's Avatar
Default Re: Bogging issue? (ef-hatchcrap)
get new spark plugs new cables new rotor and cap for the dizzy.... This should fix you problem.
Old Jul 30, 2008 | 05:01 PM
Default Re: Bogging issue? (nihad)
Nevermind I fixed the problem I had to switch the two outer wires on the tps sensor.
That should go into the faq incase someone else has the same problem.
Pkease delete
Old Jul 30, 2008 | 05:49 PM
spoonfedcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nihad &raquo;</TD></TR><TR><TD CLASS="quote">get new spark plugs new cables new rotor and cap for the dizzy.... This should fix you problem.</TD></TR></TABLE>
How can you say this will fix the problem? You get a brief description of what the problem is and you want to throw parts at it. Have you ever heard of diagnosing the problem? You sir are an idiot.
Old Jul 30, 2008 | 06:00 PM
nihad's Avatar
Default Re: Bogging issue? (spoonfedcrx)
It called maintenance. Usually cars bog because of poor ignition parts.
Old Jul 31, 2008 | 05:31 AM
Well I thought I had all the problems fixed, but while driving my newly fixed hatch I encounterd another problem.
The car starts up and idles fine but when you give it gas an lett off the idle surges like the iacv is bad
I am not throwing a code for that and I have the water lines hooked up right, could it be that it is just dirty and needs to be cleaned?
I want other opions and ieas before I got to work on it this morning.
Other thgan that car runs very strong and smooth way diffrent that when it was obd-0 im going to go get it tuned later today
Old Jul 31, 2008 | 05:54 AM
andrewsmith85's Avatar
it couldnt hurt to clean the iacv.
Old Jul 31, 2008 | 02:50 PM
Default Re: (andrewsmith85)
I found the problem turne out to be that is what the tb screw was almost alll the way backe out and causing vacume leak.
Civstang
17
Aug 22, 2011 05:08 PM
B2KHonda
Jul 1, 2009 07:12 PM
CRseX84
Jun 13, 2004 12:17 PM
Kidloco51
Jun 20, 2003 11:09 AM
