wierd power loss...vtec works, fp is good....thoughts?
Old Jul 30, 2008 | 01:51 PM
meallout's Avatar
Default wierd power loss...vtec works, fp is good....thoughts?
just swapped a b16 obd0 into an 88 hatch. Got the dual point to multi points wiring done, its all correct (checked and double checked). Fuel pressure is there, everything SHOULD be working (I drove the old car that the motor was in and its was fine). However, driving the swap around, there's no power. I'll florr it, VTEC WILL engage, I can hear it loudly, but the car doesn't respond like it should. Its like the motor only has 50 hp.
Oxygen sensor one is hooked up, number two is not, as I only have one bung in the new header. That being said, I know its a problem, but it should just run really rich, not barely run at all. I fully intend to get the other sensor in there, but I really dont' think that's the problem...thoughts?
Old Jul 30, 2008 | 01:57 PM
h0ndamatix's Avatar
Default Re: wierd power loss...vtec works, fp is good....thoughts? (meallout)
Check your timing marks and check the ignition timing/firing order as well.
Old Jul 30, 2008 | 04:39 PM
Egezzy's Avatar
Spongebrad Squarepants
yea u needa hook up the otha o2. .2 of ur cyls r basically runnin closed loop.
Old Jul 30, 2008 | 05:27 PM
khooper's Avatar
Check your vacuum hoses usually they cause the problems described and the crap out anywhere in between 50 to 100 thousand kilometers. Also try to clean fuel tank pump filter.
______________________
Check out the Eurobz Parts
Drive safely and Smile Freely
meallout
Jul 30, 2008 02:56 PM
ef8b16a1
Feb 15, 2006 05:01 PM
skunk2eg
16
Jun 9, 2004 04:05 PM
frogscivic
Jan 17, 2004 06:14 PM
bboyStatick
Nov 1, 2003 10:06 AM
