Did you Hug your Crank today ?
Crankshaft That is,
I KNOW this may be OFF TOPIC, but with so many gear heads here I figure you guys may get a kick out of the photos, but if needed please move to the correct section
Some pictures for your enjoyment :D
While some of us sleep, some of us were hugging a Crankshaft, 5 days total to remove crankshaft from engine bay out of engine room and new one installed, lots of sleepless nights but we got it done.
Enjoy the photos
Enjoy the photos
***** weak!!
http://people.bath.ac.uk/ccsshb/12cyl/
Maximum power: 108,920 hp at 102 rpm
Maximum torque: 5,608,312 lb/ft at 102rpm
***** weak!!
WE MAKE THAT ENGINE
WE MAKE THAT ENGINE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo Wax »</TD></TR><TR><TD CLASS="quote">***** weak!!
WE MAKE THAT ENGINE
You guys hiring?
WE MAKE THAT ENGINE
You guys hiring?
I've seen some guys replace a piston on a ship motor like that on discovery channel. The piston alone was something like 500,000 dollars
so how much is that crank??
Been a old engine, the lube oil pump is electrically operated, the vessel had a "blackout" which stop the lube oil pump , the oil to the engine stop, by the time the engine trip the damage was already done, the cost of that crankshaft is $650.000USD, and is a reconditioned shaft since we don't build that engine model anymore, that shaft was at one of our factory's in Trieste Italy. for any of you that have gone in cruise ships chances are they had our engines as 80 % of them have our engines. that is from a 12 cyl engine 400 mm bore, we have engines that are 20 cyl v 340mm bore and our newest one is 20 V 500mm bore
Newer engines are equip with many protections, old engines don't, few more pictures of random staff
(Click on Image for larger picture)
Big end bearing shells
When a rod goes for a walk
Vibration Damper
Removal of Cond rod housings
Piston
Con Rods
The Grandfather of the GT 42R
Biggest crusieship in the world, next to it a regular size,lol, I spend a year on that one
Vibration Damper
Piston
Con Rods
