whats your advice on this tune?
Old Jul 30, 2008 | 01:40 PM
pjr710's Avatar
Default whats your advice on this tune?
these are the current maps i'm running on my stock d16 t3 turbo, this was done by a professional tuner, but after reading the afr thread on here i feel like my af is really rich considering.
so how do these look to all of you?
Old Jul 30, 2008 | 02:01 PM
mtber's Avatar
Default Re: whats your advice on this tune? (pjr710)
Old school uberdata :-)
How much boost is the car running ?
What a/f ratio are you seeing at full throttle under full boost ?
Old Jul 30, 2008 | 03:02 PM
pjr710's Avatar
Default Re: whats your advice on this tune? (mtber)
i'm running 8-9 lbs
i dont have an a/f guage , but when he tuned it i think i am at like 10.1 at full booste at like 9 psi, then like 11 something at 8 .. i'm pretty sure most of my afr under boost are from like 11.7-10
Old Jul 30, 2008 | 05:35 PM
leoaa777's Avatar
What injectors are you running?
Old Jul 30, 2008 | 08:37 PM
mtber's Avatar
Install a wideband on the car & monitor the a/f ratios
Old Jul 30, 2008 | 10:55 PM
pjr710's Avatar
i'm runnin dsm 450s
i'm gunna have to save up for a a/f .. i'm thinkin innovative
Old Jul 31, 2008 | 03:58 PM
Rotten Egg's Avatar
10's seems really rich for a tune. i'd stick around 11.7s
but ur egt's are where its at..a wideband is nice but u want to monitor ur exhaust temps also
Old Jul 31, 2008 | 04:40 PM
pjr710's Avatar
Default Re: (Rotten Egg)
i believe it actually might be around 11.7
Old Jul 31, 2008 | 07:59 PM
Rotten Egg's Avatar
thats alot better..especially if ur just running ur fuel..now if u had meth injection or water injection it could work it up a little leaner. i know it sounds and looks corny bro but there are certain gauges that u NEED...wideband and egt being the majors..i HIGHLY recommend plx devices and there dm100 set up where u can monitor 4 parameters on 1 gauge. i love it haha
Old Jul 31, 2008 | 09:05 PM
pjr710's Avatar
u have a link for that thing?
Old Aug 1, 2008 | 06:12 PM
leoaa777's Avatar
Default Re: (pjr710)
is it a vtec d16 or non-vtec. I am guessing vtec due to the high cam values..but double checking regardless.
Old Aug 1, 2008 | 10:13 PM
Rotten Egg's Avatar
Default Re: (leoaa777)
http://www.plxdevices.com
look up the dm 100
Old Aug 2, 2008 | 12:24 AM
locash's Avatar
Where do you get the idea that an EGT is a must have gauge?
Old Aug 2, 2008 | 08:19 AM
Rotten Egg's Avatar
Default Re: (locash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locash &raquo;</TD></TR><TR><TD CLASS="quote">Where do you get the idea that an EGT is a must have gauge?
do u know what the ideal air fuel ratio is for ur engine? if u say yes then how did u come with that answer? did someone recommend it? running an air fuel ratio gauge and an exhaust temp gauge together u can come up with an exhaust signature for ur car and u will KNOW what the best afr is for ur engine. just cuz ur running a 11.9 afr and is consider safe for ur engine by the masses of people u could be running a unsafely high exhaust temp which means ur engine is being starved and u would never know...
ive seen alot of turbocharged engines fail due to high exhaust temps but good air fuel ratios.
but as like everything else this is just my opinion..nothing is mandatory but i figure u drop a good 7 grand or more into a nice turbo set up and engine build whats another 100-150 bucks for a sensor to monitor temps
Old Aug 2, 2008 | 08:49 AM
HRTuning's Avatar
You have Uberdata. You can use the TunerView LCD and monitor 4 EGTs with that.
Old Aug 2, 2008 | 11:42 AM
pjr710's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leoaa777 &raquo;</TD></TR><TR><TD CLASS="quote">is it a vtec d16 or non-vtec. I am guessing vtec due to the high cam values..but double checking regardless.</TD></TR></TABLE>
its vtec
how is my timing? is it conservative and safe? or do some ppl go a little more aggressive?
Old Aug 6, 2008 | 08:00 PM
leoaa777's Avatar
I would go a bit lower on the high cam and low cam timing on boost just to be safe and if you dont have anythign to monitor your AFRs.
Judge Owens
Feb 28, 2015 06:00 PM
406EVO
Engine Management and Tuning
Oct 18, 2011 10:39 AM
jdm91CrxSi
Jun 28, 2008 08:25 AM
Andrew 825SM
Sep 22, 2002 01:26 AM
