88 EF Rims and Tires
Old Jul 30, 2008 | 12:56 PM
88 EF Hatch's Avatar
Default 88 EF Rims and Tires
Im going to get some 15x7 red rota track r's. What size tires should I wrap them in?
Old Jul 30, 2008 | 01:13 PM
zrickety's Avatar
Default Re: 88 EF Rims and Tires (88 EF Hatch)
are you running the stock motor or a swap? B series gets 205/50R15. check the tire rack it will give you some options
Old Jul 30, 2008 | 01:19 PM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
Default Re: 88 EF Rims and Tires (zrickety)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zrickety &raquo;</TD></TR><TR><TD CLASS="quote">are you running the stock motor or a swap? B series gets 205/50R15. check the tire rack it will give you some options</TD></TR></TABLE>
I'm sorry, but engine swaps have zilch to do with tire size. You got the size right, but a B/D/K shouldn't really matter. 205/50R15 ftw on those wheels tho.
Old Jul 30, 2008 | 01:20 PM
well im running stock right now but im going with a b16a xsi in about a month. So 205/50R15 is what i should get?
Old Jul 30, 2008 | 01:23 PM
Ok. I was being offered some 205/65/R15....should i do those or the 205/50/R15?
Old Jul 30, 2008 | 01:25 PM
se-real's Avatar
Hahaha, yes. 205/50's are a really good combo for a 15x7" wheel on a ef. I have ran 195/50's before but only because i got a really good deal on em! If your car is lowered, a205/50 is generally about as wide as you can go before you start rubbing etc etc.
Old Jul 30, 2008 | 01:27 PM
se-real's Avatar
Default Re: 88 EF Rims and Tires (se-real)
no, the 205/65's will be too tall. IMO, it will make the 15" wheel look too small. Plus once again, if your lowered, you will have issues with the 65 series tire.
Old Jul 30, 2008 | 01:56 PM
Ok thanks that really helped a lot. Nd i am not lowered yet but do plan on doing it i just started working on my car. Here is how it looked like when I got it.
Here is what it looks like now
Here it is next to a homie's JDM EF9
What do you think of my transformation?
Old Jul 30, 2008 | 02:11 PM
EvanFullwood's Avatar
195/50/15 or 205/50/15 are the best.......bfgs are great
Old Jul 30, 2008 | 02:23 PM
traxxasx's Avatar
another perfectly wasted good paint job down the drain to spray paint, flat black.
Old Jul 30, 2008 | 02:30 PM
traxxasx's Avatar
Default Re: (traxxasx)
Anyways we have an ef meet every sunday at the in and out on lake mead and rock springs, or rainbow. at 8pm.
your welcome to come were always looking for new people.
461-9719 heres my number is you need it.
Also i know the asian dude with the green hatch. For got his name.
He was also selling a black celica.
Old Jul 30, 2008 | 02:33 PM
mit7059's Avatar
Black hatch in Nevada? I hope for your sake you've got a/c
Old Jul 30, 2008 | 02:59 PM
zrickety's Avatar
Default Re: 88 EF Rims and Tires (ComeOnKip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComeOnKip &raquo;</TD></TR><TR><TD CLASS="quote">I'm sorry, but engine swaps have zilch to do with tire size. You got the size right, but a B/D/K shouldn't really matter. 205/50R15 ftw on those wheels tho.</TD></TR></TABLE>
Kip, i usually agree with your posts. However, swaps definitely DO make a difference. For example:
Stock D 205/40R16
Stock B 205/45R16
Stock K 205/55R16
I use 16's for reference because of K-swaps. You want to run tires that match the drivetrain, not the car. The K uses a significantly taller tire. I realize these are not huge differences, but it may be a few MPH that determine if you get a ticket
Old Jul 30, 2008 | 05:47 PM
1.8 HAMSTER EF's Avatar
gold track r's would look good
Old Jul 30, 2008 | 06:14 PM
gsxrallday's Avatar
im currently running 205/55/15 white track R but they rub once i go hard on turns and i have the skunk 2 type s ,skunk2 upper and lower rear bar and nuespeed front and a cross bar in teh trunk and it still rubs going thru turns hard so i would suggest going with 205 50 15 with them
Old Jul 30, 2008 | 08:33 PM
ChAlexEF9's Avatar
i got 195/50/15 and its all good
Old Jul 30, 2008 | 08:40 PM
BigDare23's Avatar
the proper size is 195/50/15
Old Jul 30, 2008 | 09:29 PM
xsirenax's Avatar
Default Re: 88 EF Rims and Tires (gsxrallday)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsxrallday &raquo;</TD></TR><TR><TD CLASS="quote">im currently running 205/55/15 white track R but they rub once i go hard on turns and i have the skunk 2 type s ,skunk2 upper and lower rear bar and nuespeed front and a cross bar in teh trunk and it still rubs going thru turns hard so i would suggest going with 205 50 15 with them </TD></TR></TABLE>
roll your fenders so they dont rub....its your rear tires that rub at turns right?
Old Jul 30, 2008 | 10:12 PM
Ok i like the 195/50/r15's but does any one have pics of the 205/50/r15's? and traxx asx where is rock springs? I'll hit you up cuz i usually work sundays.. I work at the autozone on silverado ranch blvd and maryland parkway if you need parts man
Old Jul 31, 2008 | 12:00 AM
My_EFsedan's Avatar
Default Re: (88 EF Hatch)
heres mines (track R) and my cousins slips.
i had 205/50/15's. love how they grip.
he had 205/55/15's a lil rub issue on u turns
my new rims im getting tomorrow are 195/50/15s. shop recommended that i run the 195's because i have no camber kits. they said that it will be a less camber issue than the 205's i had.
Old Aug 1, 2008 | 05:37 PM
jon4honda's Avatar
gotta love the slips those track r's are some bad mofoes
Old Aug 1, 2008 | 06:18 PM
MyHotsh's Avatar
195/50/15 Dunlops..
Old Aug 1, 2008 | 07:40 PM
Aristotle's Avatar
195/50R15
Old Aug 1, 2008 | 07:46 PM
Slystone's Avatar
Default Re: (Aristotle)
i try a lot of size and brand and for 15x7 Azenis 205-50-15 are best for our EF!
Old Aug 2, 2008 | 05:39 PM
jon4honda's Avatar
Default Re: (My_EFsedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by My_EFsedan &raquo;</TD></TR><TR><TD CLASS="quote">heres mines (track R) and my cousins slips.
wat kind of rims are those and where did you buy them thanks in advance love the hatch
Modified by jon4honda at 10:47 AM 8/3/2008
