D16A6 mystery!
Old Jul 30, 2008 | 12:30 PM
swiF_blaK's Avatar
Default D16A6 timing puzzel (searched and searched!)
90 civic hatch frankentsteined by the the previous owner. Unable to identify the head but I will post pics asap
D16A6 block
Aftermarket but seemingly generic CAI/IM/H/Muffler
during my commute to work 1 day my hatch lost power and the exhaust note changed quite noticeably (louder, more sharp like a old lawnmower).
I’ve done a lot of searching in the last 2 weeks and its evident this engine needs some expensive internal work done (long overdue work, I know).
in an effort to get the car drivable again until a rebuild is more feasible, i planned on checking the timing hoping to readjust and be temporarily back in business. thats when i noticed my adjustable cam gear was missing 2 of the 6 bolts holding it on the cam. i'll post a pic asap.
I apologize for the lengthy intro. absolutely ANY help, advice, suggestion, etc. is appreciated.
if you made it this far…thanks.
Modified by swiF_blaK at 5:39 PM 7/30/2008
Old Jul 30, 2008 | 01:09 PM
fireant's Avatar
Default Re: D16A6 mystery! (swiF_blaK)
I think your timing belt might have skipped a tooth there.
First address the timing belt and make sure its correct (or as correct as it can be with that particular head) then move on to a leakdown test to find out which valves or rings are taking the oil.
Old Jul 30, 2008 | 04:58 PM
swiF_blaK's Avatar
Default Re: D16A6 mystery! (fireant)
Hey thanks !
heres a pic of the head's stampings
[IMG][/IMG]
and heres a shot from the top
[IMG][/IMG]
any help identifying this head is much appreciated.
and heres a shot of my cam gear at a random position
[IMG][/IMG]
can i reliably set the timing with this setup in the event my belt jumped a tooth?
clearly wouldnt be ideal, but i just need to get this thing back on the road so i can get it to a garage for some teardown.
thanks again in advance
Old Jul 30, 2008 | 05:19 PM
efsublime's Avatar
looks like a z6 or a d15b7.
Old Jul 30, 2008 | 05:31 PM
swiF_blaK's Avatar
Default Re: (efsublime)
cool thanks for the input
im gonna mess with the timing and see what i can do. hopefully it only gets better from here.
Old Jul 31, 2008 | 03:35 PM
fireant's Avatar
Default Re: (swiF_blaK)
With a timing gun you'll be able to tell pretty quick if its off a tooth. The full adjustment range of the distributor will not come close to lining up the notches on the crank pulley with the pointer.
Old Jul 31, 2008 | 07:29 PM
Bserieskllr's Avatar
i would check timing first like the others stated and its a d16z6 head
Ef4doorwagon
May 14, 2015 07:33 PM
Ef4doorwagon
Mar 26, 2014 06:42 PM
gramentz
Feb 22, 2013 08:12 AM
RicedREX
Sep 8, 2004 02:14 PM
JDMs1eeper
Aug 20, 2003 09:15 AM
