ecu help after searching.
Old Jul 30, 2008 | 09:58 AM
mrvrsick's Avatar
Default ecu help after searching.
so i searched for a while and here it goes:
i have a dohc zc in my hb si. i have the pm6 ecu. ive read that the pg7 would be better and the pm7 being optimal, but having a speed limiter. so can somone clarify the problems with switching to pg7? ive heard a slew of problems ranging from codes to idle and not running all together. my car runs fine and no codes at all so i dont want to put something in that will make it run like crap.
also im losing brake pressure and im wondering if it has something to do with the vacuum connection that i plugged on the top center of the intake manifold.
phew.
Old Jul 30, 2008 | 02:03 PM
ktp1598's Avatar
I had a dohc ZC in a 91 hatch with a PM6. I switched to a PG7 and I never got a Cel. Mine ran fine. Of course, every application is different. It seems gremlins follow some cars. If your interested, I have a PG7 on egay right now, from a 1989 teg 5 speed. # 220262834161 If you are happy with your set up the way it is, leave it alone. As far as the brakes, it sounds like you either have a leak somewhere or the M/C is going bad. Try bleeding the brakes. The only hose that would affect the brakes is the one that goes to the booster behind the master cylinder. Of course, check pad and shoe thickness.
Old Jul 31, 2008 | 01:39 PM
mrvrsick's Avatar
where does that vacuum line go tho?
Old Jul 31, 2008 | 01:49 PM
ktp1598's Avatar
Default Re: (mrvrsick)
The large center one on the front engine side goes to the egr valve and the one on the right goes to the fuel pressure reg.
http://www.swappedandboosted.com/images/ZC.jpg See if this works.
Old Aug 1, 2008 | 09:24 PM
mrvrsick's Avatar
Default Re: (ktp1598)
no, the one on the back of the intake man. closer to the tb
Old Aug 2, 2008 | 05:46 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrvrsick &raquo;</TD></TR><TR><TD CLASS="quote">no, the one on the back of the intake man. closer to the tb</TD></TR></TABLE>if you have 2 vacuum ports on the back of the intake manifold close to the throttle body, your engine was from an automatic transmission car - ports aren't there on the manual engine - just cap those 2 ports off - don't connect them together - the big vacuum port on the front of the intake manifold, in between the 2 smaller ones, is for the PCV valve - the brake booster vacuum line is on the left (on end of manifold) in the picture below
Old Aug 2, 2008 | 12:16 PM
mrvrsick's Avatar
yes! thank you! and i guess i got one from an auto car =/
1990civicsiguye
Jul 30, 2003 06:21 PM
blackEF
Oct 18, 2002 11:09 PM
civteg1
Mar 1, 2002 05:32 AM
Hondasaurs
Nov 5, 2001 04:35 PM
