valve seals, which ones do you guys use?
Old Jul 30, 2008 | 09:38 AM
95dxsir2's Avatar
Default valve seals, which ones do you guys use?
I'm pondering buying oem,aftermarket, or aftermarket "performance" valve seals.
which do you guys use? i'm planning for 300+ hp to the wheels with probably 12-14 psi boost.
Also, what valve keepers are you using.
thanks
i have titanium keepers and type-r dual valve spings. gsr cams
Old Jul 30, 2008 | 10:42 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: valve seals, which ones do you guys use? (95dxsir2)
oe
Old Jul 30, 2008 | 11:49 AM
95dxsir2's Avatar
Default Re: valve seals, which ones do you guys use? (boostedcivicsir)
for both?
thanks
Old Jul 30, 2008 | 02:54 PM
blwn95civic's Avatar
oem here
Old Jul 30, 2008 | 05:08 PM
hotrod99's Avatar
Default Re: valve seals, which ones do you guys use? (blwn95civic)
i used Supertech viton seals on my build with no problems so far
Old Jul 31, 2008 | 04:27 AM
urbansi's Avatar
Default Re: valve seals, which ones do you guys use? (hotrod99)
oem, replaced at 90k 400whp now
Old Jul 31, 2008 | 06:37 AM
95dxsir2's Avatar
Default Re: valve seals, which ones do you guys use? (urbansi)
thanks guys!
Brembomaster
Engine Machining & Assembly
May 7, 2019 03:33 PM
Natural Aspirations
Feb 6, 2014 03:35 AM
existanzcivicb20
Apr 12, 2006 01:30 PM
quiksheit
May 26, 2005 02:36 PM
