trying to deghetto a 91 da
Old Jul 30, 2008 | 07:58 AM
hondaman1212's Avatar
Default trying to deghetto a 91 da
i traded my car 92 si hatch for a 91 da with a turbo with some cash and wheels long story i will post pics in one second. anyways i throwing codes 17 no speedometer and codes 43 after doing some searching and looking at what he setup i cant find an o2 sensor. right now the car is running open downpipe so should i buy an 02 sensor and wire it in? the car has alot of potential.i just need to put a little loving care into it.
Old Jul 30, 2008 | 09:02 AM
ivanvtec's Avatar
Default Re: trying to deghetto a 91 da (hondaman1212)
well if you dont see an O2 sensor on the exhaust manifold for some reason then yes, you should buy an O2 sensor and wire it in. the last thing you want are wrong air/fuel ratios making your car slower.
Old Jul 30, 2008 | 09:08 AM
ivanvtec's Avatar
also with your speedometer check if the speed sensor on the tranny hasn't broken since that one bolt that holds it in place is usually what causes it to break when it is over tightened. If that looks good then check the cable that runs from the top of the speed sensor. that cable requires a clip to stay in place and it can come out randomly giving you no reading on the speedometer. this happened with my friends DA so hopefully it can solve you issue. good luck man
Old Jul 30, 2008 | 09:59 AM
Default Re: trying to deghetto a 91 da (ivanvtec)
thanks im about to post pics up. im so glad i traded the hatch for the da is just sexy!!!!thanks for all your help everyone. i have to work till 7 all week so i wont be able to fix it till the weekend.
Old Jul 30, 2008 | 10:13 AM
Old Jul 30, 2008 | 10:15 AM
Old Jul 30, 2008 | 12:42 PM
hotrod99's Avatar
what ems is the car running?
bhall123
Honda Civic (2006 - 2015)
Apr 16, 2018 03:26 AM
minituner
Mar 26, 2016 04:16 PM
charliewolf_0
Mar 16, 2012 03:25 PM
harryhood
Dec 23, 2005 06:06 AM
hondaaccord94
Mar 26, 2005 07:40 PM
