0BD1 B16 Intake Manifold
Does anyone know if I could use a 99-00 USDM Civic Si (OBD2) Intake Manifold on my 0bd1 B16? I want to BAR (California) this engine and need a USDM Intake Manifold. I know I could use a DOHC Del Sol Manifold, just wondering if I have other options.
Thanks in advance.
And yes, I searched and went through the FAQs..
Thanks in advance.
Im going to get my car bar'd im purchasing a skunk2 intake manifold that will fit all b16's, 17's & 18's and is CA carb legal..
cost about 240 bucks shipped..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sp00nedED »</TD></TR><TR><TD CLASS="quote">Does anyone know if I could use a 99-00 USDM Civic Si (OBD2) Intake Manifold on my 0bd1 B16? I want to BAR (California) this engine and need a USDM Intake Manifold. I know I could use a DOHC Del Sol Manifold, just wondering if I have other options.
Thanks in advance.
You probably can but your set up probably needs to be OBD2 Civic Si. I'm going to BAR it OBD1 soon also.
Thanks in advance.
</TD></TR></TABLE>You probably can but your set up probably needs to be OBD2 Civic Si. I'm going to BAR it OBD1 soon also.
Thanks in advance.
And yes, I searched and went through the FAQs.. </TD></TR></TABLE>
You didn't search good enough...
It will only work if you tap a vacume line in the back of the manifold by the brake booster for the EVAP purge solenoid...
Also, 99-00 SI's have the IAT sensor on the intake tube, while obd-1 DelDol VTEC has it on the Intake Manifold... I would just go with the Skunk2 because its carb legal, and has the spots for both sensors. I passed BAR with it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aristotle »</TD></TR><TR><TD CLASS="quote">B16 intakes and B18 intakes are different.</TD></TR></TABLE>
B16 and B18C5 have the same heads....
Thanks in advance.
sp00nedED
Jul 30, 2008 11:00 PM
