my ef took a crap on me...
Old Jul 30, 2008 | 01:57 AM
civicb16eg's Avatar
Default my ef took a crap on me...
wat a bad day/nite...First off i wanted to change my axles for my car.. i called up kragen and they said they had so i went there and what do u know they dont have it..nothing new...so i place one on order so i can pick up for free with my lifetime warranty.so i go over to my cousins and chilled there for a bit and what do u know my phone's battery decides to crap on me... so now its about 12 AM and i decide to go home...on my way home what do u know my car decides to crap on me tooo!!! [freak]!!! now my car is dead and my cell is dead.. so i walk to seven eleven in hope of using there phone but what do u know they say they dont have one ****!!.. then i asked a guy who has to use his cell phone and what do u know he has a gay *** metro that doesnt even [freak]ing work !! so i decide to run over to my cousins which was roughly a quarter mile away and luckily he wasnt asleep.. so i used his phone and called the tow truck... now i just got home via tow truck and trying to figure out wat is wrong..
Now heres the problem.. the car is an 88 civic hacth with a b20 swap.. car ran fine prior to today but when i was at a stop light this early morning the car just dies.. at first the car would crank and sounded like it would start but of course it didnt..then after a few cranks the car completely doesnt want to crank nemore.. the fuel pump is priming but the car does not crank at all.. what can be the problem? there is no CEL.. could it be the battery? dizzy? starter? alternator? nething else yall can think of would be nice...
Old Jul 30, 2008 | 02:37 AM
traxxasx's Avatar
Default Re: my ef took a crap on me... (civicb16eg)
I would resolder the contact points on your main relay.
Old Jul 30, 2008 | 10:48 AM
hushypushy's Avatar
Default Re: my ef took a crap on me... (traxxasx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by traxxasx &raquo;</TD></TR><TR><TD CLASS="quote">I would resolder the contact points on your main relay.</TD></TR></TABLE>
If the main relay was dead the fuel pump wouldn't prime at all.
Old Jul 30, 2008 | 11:06 AM
Creator's Avatar
Did you notice your headlights dimming or interior lights doing the same? Did the car do anything funny prior to stopping at the light?
Old Jul 30, 2008 | 11:09 AM
civicb16eg's Avatar
Default Re: my ef took a crap on me... (Creator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Creator &raquo;</TD></TR><TR><TD CLASS="quote">Did you notice your headlights dimming or interior lights doing the same? Did the car do anything funny prior to stopping at the light?</TD></TR></TABLE>
the car did not do nething funny when stopping at the light..the car just died. when trying to turn the car on the dash lights go dim..
Old Jul 30, 2008 | 11:49 AM
JustAnotherRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicb16eg &raquo;</TD></TR><TR><TD CLASS="quote">
the car did not do nething funny when stopping at the light..the car just died. when trying to turn the car on the dash lights go dim.. </TD></TR></TABLE>
I'd try jumping it if you haven't already.
From there, I'd check for fuel and spark.
Old Jul 30, 2008 | 01:06 PM
ktp1598's Avatar
Check your ground and all battery cable connections. Have the battery tested and then the alternator if everything else is ok. Thats where I'd start.
Old Jul 30, 2008 | 10:01 PM
civicb16eg's Avatar
Default Re: (ktp1598)
it was the battery.. jumped it and everything is fine...but i have another question doesnt the car run on the alternator after the car has been started? so does this mean that my alternator is not working properly?
Old Jul 30, 2008 | 10:07 PM
xsirenax's Avatar
yes the car runs on the alternator after you start it the battery is only to start the car the alternator powers up the car if your alternator doesnt work heres a easy way to check
turn the car on then disconnect the battery if it shuts off your alternator dont work
if it stays on its fine
Old Jul 30, 2008 | 10:18 PM
D16SiHatch's Avatar
Default Re: (xsirenax)
thats retarded. put a multimeter on the battery when the cars running. if its somewhere around 14.0 then the alt's working fine. if you start getting into low 13's or 12 somethin, then you have an issue with your charging system.
Old Jul 31, 2008 | 01:37 AM
drummingpariah's Avatar
Default Re: (D16SiHatch)
Both methods work, but I suggest the multimeter. It'll give you a better idea of what's actually going on, rather than just a thumbs up or thumbs down.
kilassapsap
May 23, 2011 05:23 PM
kris9
16
Apr 29, 2010 01:39 PM
ef8jdm
Jan 7, 2010 02:46 PM
stockbee
52
Jun 2, 2006 06:50 PM
91SIvic
Feb 15, 2003 10:15 PM
