HELP installing ebay spoon mirrors
Old Jul 29, 2008 | 08:35 PM
ase2's Avatar
Default HELP installing ebay spoon mirrors
i just got these in the mail and i got stuck on the wiring part and i've searched already and cant find nothing. the harness that comes with it, hooks up to the connector from the mirror so im left with open ends to four wires (black, blue, white, brown) from the mirror. the stock connector from the car only has three yellow wires hooked up to it. so i guess i gotta cut the connector off but i dont know which wires go together. hopefully i make my self clear??? i searched around, googled it, and check the ebay store for instructions n found nothing.
Old Jul 30, 2008 | 07:11 AM
ase2's Avatar
63 views and nothin??? i guess im the only one with these?? fawk im stuck
Old Jul 30, 2008 | 07:27 AM
Rickdrizzle's Avatar
You obviously didn't search enough.
Keep looking, I recall helping some guy out in a thread awhile ago. Apparently, you don't need one of the wires, since only 3 is required. I forgot which one it was.
Old Jul 30, 2008 | 07:49 AM
istoleurgirl's Avatar
Default Re: (Rickdrizzle)
DON'T cut the connector's off, just tap into the wire... incase you want to go back to stock, the connector is still there.. but yea sorry can't help with the wiring.. if i had to make an educated guess i'd say exclude the brown wire.. trial and error.. what's the worse that could happen a blown fuse? just replace and try again....
Old Jul 30, 2008 | 08:05 AM
Default Re: (istoleurgirl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by istoleurgirl &raquo;</TD></TR><TR><TD CLASS="quote">DON'T cut the connector's off, just tap into the wire... incase you want to go back to stock, the connector is still there.. but yea sorry can't help with the wiring.. if i had to make an educated guess i'd say exclude the brown wire.. trial and error.. what's the worse that could happen a blown fuse? just replace and try again....</TD></TR></TABLE>
It took me two fuses to find the correct wire.
Old Jul 30, 2008 | 08:27 AM
ase2's Avatar
i would still have to cut the wire to join it with the wire from the mirror n then tape the connectors end wire to it right???
Old Jul 30, 2008 | 10:12 AM
Default Re: (ase2)
they sell wire taps, u cut a small slit in the original rubber til the wire is exposed, attach the clip to the exposed wire( it clamps on it) and connect the the male end to the female end on the tap.. or you could do it your way.. either way.. just trying to save you a headache in the future... good luck
Old Jul 31, 2008 | 07:07 PM
ase2's Avatar
i went to my local hardware store n said they dont know what WIRE TAPS are.....so therefor im still lookin. is there another name for these or an online store i can buy them from?
Old Oct 26, 2008 | 09:10 PM
ImportHatch's Avatar
Default Re: (ase2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ase2 &raquo;</TD></TR><TR><TD CLASS="quote">i went to my local hardware store n said they dont know what WIRE TAPS are.....so therefor im still lookin. is there another name for these or an online store i can buy them from?</TD></TR></TABLE>
Any schucks or napa should have those.
toolow69
11
Dec 14, 2013 05:16 PM
95itr-ej2
Sep 10, 2012 02:47 PM
lilo_goki
Feb 25, 2009 09:52 PM
ibemike
Mar 21, 2007 11:26 PM
ibemike
Dec 18, 2006 10:04 PM
