supercharged b18b
Old Jul 29, 2008 | 07:23 PM
peter_b16's Avatar
Default supercharged b18b
soooooo..i installed my supercharger onto my car today(b18b crx)..it feels pretty kool as i am boostin 8lbs..the jg 303 cams really made a big difference too..has anybody ever had any experience or can relate to my build???im not to sure how its suppose to perform but it doesnt feel as fast as my b16 swap...any advice or info would help as i am the only person i know wit this build..or at least that i can find...
Old Jul 29, 2008 | 08:03 PM
vtecb18c's Avatar
Default Re: supercharged b18b (peter_b16)
if it doesnt feel faster than your b16 than it needs to be tuned...have you done a dyno/tune session?
Old Jul 29, 2008 | 10:00 PM
peter_b16's Avatar
Default Re: supercharged b18b (vtecb18c)
i had it street tuned a lil when i first got the charger in..then later on, i had the cams installed wit no tune...now it seems to run rich..but isnt rich better than lean?? the cams shouldnt change the tune that much more should it??
Old Jul 29, 2008 | 10:03 PM
vtecb18c's Avatar
if there not cams for boosted apps than that could be your problem right there..you need it re tuned if its running rich and because you have diff cams
Old Jul 29, 2008 | 10:11 PM
SIred91's Avatar
Rainman
That should RAPE a B16 swap.
Old Jul 30, 2008 | 01:59 PM
xalents23's Avatar
What alternator pulley are you running on your setup? I am running into issues with my 1991 CRX with a OBD0 B16A1 swap. I have the 99-00 Civic SI JRSC. Any info would be greatly appreciated. The JRSC alternator pulley I got is to big. Here is the JRSC alternator part # 051-109.
Old Jul 30, 2008 | 04:22 PM
Crx Jimmy's Avatar
Default Re: (xalents23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xalents23 &raquo;</TD></TR><TR><TD CLASS="quote">What alternator pulley are you running on your setup? I am running into issues with my 1991 CRX with a OBD0 B16A1 swap. I have the 99-00 Civic SI JRSC. Any info would be greatly appreciated. The JRSC alternator pulley I got is to big. Here is the JRSC alternator part # 051-109.</TD></TR></TABLE>
you need to use a obd2 alternator or get the spacer bushing to install on a obdo or obd1 alt inside the pulley. thats what I have. I got the bushing from jim at motorvations
Old Jul 30, 2008 | 06:08 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (Crx Jimmy)
What tranny are you using?
Old Jul 30, 2008 | 09:53 PM
peter_b16's Avatar
i am currently runnin the jg 303 cams..i think i am runnin too rich..but that cant mess it up that bad..can it???oh yea..im usin a ls tranny..i did have on a b16 tranny but it grinds to much..so i took it out..i do miss it..that **** seems to rip faster than the ls tranny..
Old Jul 30, 2008 | 10:02 PM
peter_b16's Avatar
oh yea...i took the car to the track earlier..the best i could get down was 15 flat...THATS SLOW AS [freak]!! but 1 problem was that i didnt install that lil bracket to hold down the speed cable and the car would stall whenever that **** came loose (and that **** came loose every run)..but its because i have the launch control set at 3.5k..and i couldnt go pass that after the cars rpm dropped under 3.5k rpm....
Old Jul 30, 2008 | 10:50 PM
ph3ar's Avatar
Default Re: (peter_b16)
Get a better transmission and a dyno tune, just my .02.
Old Jul 31, 2008 | 05:25 AM
gibsanez's Avatar
Get a dyno tune before you blow your **** up, and stop beating on it until then. Otherwise, you might as well start a new thread now, titled "Why does my supercharger make my engine smoke 3 different colors?"
Old Jul 31, 2008 | 06:04 AM
hotrod99's Avatar
[QUOTE=peter_b16]im not to sure how its suppose to perform but it doesnt feel as fast as my b16 swap...QUOTE]
theres something extremely wrong then...you really need to have it dyno tuned what kinda fuel managment are you running?
Old Jul 31, 2008 | 08:47 AM
_Keith_'s Avatar
One are those cams for boosted cars?
Two... Running rich can cause problems too!
Three GET IT TUNED BEFORE YOU BLOW IT UP! Id never race a car at the track on a half *** street tune.
and you have the same setup im building for. But im going for much more then 8 psi on that supercharger.
Old Jul 31, 2008 | 09:14 AM
xalents23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
you need to use a obd2 alternator or get the spacer bushing to install on a obdo or obd1 alt inside the pulley. thats what I have. I got the bushing from jim at motorvations</TD></TR></TABLE>
Thanks CRX Jimmy I just called Jim at motorvations and he knew exactly what I needed. Ordered the alternator shaft shim for my hybrid JRSC.
Old Jul 31, 2008 | 01:29 PM
peter_b16's Avatar
Default Re: (gibsanez)
i know..but i just wanted to see a figure before i get it tuned..im currently runnin stock fpr and im just usin dsm 450cc tuned on CHROME..but knowing that i run 15 flat makes me not want to get my car dyno tuned...i dont know if itll help that much more..ive seen one of my buddies dyno tuned his car to get the same time at the track..but ill see..
Old Jul 31, 2008 | 01:35 PM
D16SiHatch's Avatar
a stock ls swapped in an ef can do about 15 flat, so if your only running 15.0 and your cars supercharged, somethings majorly wrong. a good tune will be your friend
Old Jul 31, 2008 | 01:43 PM
SIred91's Avatar
Rainman
Default Re: supercharged b18b (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16SiHatch &raquo;</TD></TR><TR><TD CLASS="quote">a stock ls swapped in an ef can do about 15 flat, so if your only running 15.0 and your cars supercharged, somethings majorly wrong. a good tune will be your friend</TD></TR></TABLE>
Like I said.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">That should RAPE a B16 swap.</TD></TR></TABLE>
You have major issues with your setup.
GET IT TUNED RIGHT.
Old Jul 31, 2008 | 01:47 PM
hotrod99's Avatar
shouldve went the turbo route if you actually wanted to go fast
Old Jun 26, 2009 | 09:55 PM
tek_civic's Avatar
a search revealed this to me. How about an update? got a JRSC for sale? haha j/k
Old Jun 27, 2009 | 07:11 AM
Deetz's Avatar
Crazy Honda Guy
You said exactly what i was thinking. Using cams with high lift were designed to run great for N/A, but **** for boosted applications....unless of coarse you got a grind made special for it.
My setup cost less and makes more power. Using a B20Z with P8R head and JR supercharger which runs at 9 lbs. HP and torque for the street are deadly.
Old Jun 27, 2009 | 07:19 AM
conceptEG's Avatar
tune.. or be like me = boom
your cams ad lift thus needing more fuel especially when supercharged.
i have toda spec'bs in my b16a with ctr piston set up.
i just bought the car and she blew a few days later... seems when they hacked with a vafc2 they changed the v-tec engagement to 3300... calling for more fuel. the engine leaned out due to no maf ( none on any Honda) and melted the ctr's to near nothing.
you need tuning and don't use some friends great idea. at least get comepro,neptune,hondata etc ( if you are like me and are an obd-1 ef )
Old Jun 27, 2009 | 09:14 AM
jhammond_82's Avatar
Reject Papi
uhh, guys, this thread is from last july.
Old Oct 26, 2009 | 10:49 PM
angryhillbilly's Avatar
would you rather have a short or long tranny for sc?
Old Oct 27, 2009 | 12:49 AM
DCRB's Avatar
since you asked, i'd make a hybrid trans, with short 1st through 3rd (b16 gears) then the ls 4th and 5fth
