Typical vibration drivers front. 95 cx with gsr swap.
Old Jul 29, 2008 | 07:22 PM
aquabob89's Avatar
* B A N N E D *
Default Typical vibration drivers front. 95 cx with gsr swap.
Symptons.
Car has a bad movement issue in the wheel at about 75 mph.
It doesnt go away with the car in neutral. While applying the brakes it becomes worse.
It recently about 2 days ago started making a swishing sound while in neutral or with no acceleration going downhill. Its going normal-normal-normal-swish. In a rotating order.
Another symptom is when you let off the gas something starts to tap sparatically, dun-dun-dun very fast.... but if you apply a little bit of gas or hold it steady it stops.
Im wondering what my issues could be. The car has had passenger side axel and bearing replaced in the past 3 months.
Are these symptoms typical with a bad bearing or axel?
I should also mention the lug nuts are not staying tight for some reason. I got out of my car when this first started to happen and two lugs were hand tight.
Thanks for your help.
Old Jul 29, 2008 | 07:28 PM
vtecb18c's Avatar
Default Re: Typical vibration drivers front. 95 cx with gsr swap. (aquabob89)
possibly hub bearing? make sure your lugs are torqued to about 75ft lbs drive it for about a mile than do it again and they shouldnt come loose after that
Old Jul 29, 2008 | 07:57 PM
aquabob89's Avatar
* B A N N E D *
Default Re: Typical vibration drivers front. 95 cx with gsr swap. (vtecb18c)
Yea. how much do wheel bearings cost
Old Jul 29, 2008 | 07:58 PM
vtecb18c's Avatar
i think like 60 bucks
TurboCivicR93
Suspension & Brakes
Oct 13, 2011 11:32 AM
0618turbocivic0618
Suspension & Brakes
Jun 29, 2007 08:01 AM
e jay one
10
Mar 21, 2007 11:37 AM
civicb16eg
11
Oct 26, 2006 03:12 PM
jdmcivic1999
Nov 18, 2005 05:54 PM
