Engine shuts off when slowin down.
Old Jul 29, 2008 | 07:17 PM
CRX30436's Avatar
Default Engine shuts off when slowin down.
whats up guys. Im havein a problem with my car. What it does is, when i stop at a red light or stop to make a turn my engine will idle down of course but when i give it some gas the engine will die. So then i will turn the key all the way back and restart the car again. An the process happens all over again..... Now i have already replaced the fuel filter, so when rule that out...... Anymore ideas of what it might be?
Old Jul 29, 2008 | 07:50 PM
blackmfoggie's Avatar
Default Re: Engine shuts off when slowin down. (CRX30436)
it sounds like an electrical problem. my cb7 did the same thing. after researching i finally realized that it was a crank/tdc sensor in the distributor. do the ecu throw any codes
Old Jul 29, 2008 | 08:00 PM
CRX30436's Avatar
Default Re: Engine shuts off when slowin down. (blackmfoggie)
No codes what so ever.
Old Jul 29, 2008 | 08:10 PM
you drive an ef right? check the carb or distributor. just take it to a shop and see what they say and let me know
Old Jul 30, 2008 | 06:51 AM
CRX30436's Avatar
Any other takers?
Old Jul 30, 2008 | 08:03 AM
recycled air 90's Avatar
with my EF when i use to hit the brakes all my dashboard lights would come on and my engine would die....or if i threw it in reverse the same thing would happen....it turned out to be a loose ground in between my tailights...maybe check that? idk just some food for thought
AudioFunk
Jul 29, 2013 11:02 AM
oneslowstd
Oct 7, 2011 06:48 AM
tennisboy
Jul 27, 2008 07:05 AM
Itu
Jun 21, 2006 10:39 AM
friedEGs
Feb 8, 2005 08:54 PM
