seat pan swap, need of help immediately!!!
Old Jul 29, 2008 | 05:04 PM
lunalink's Avatar
Default seat pan swap, need of help immediately!!!
I recently baught a pair of seats off a '93 acura integra 2 door..i switched everything and i found out that i have to do a seat pan swap..does anyone know what i need inorder to actually make this happen? or if you have a web site or a video that would help alot!!
the only thing i do know is that im going to need some clamps and a pair of special plyers to back the covers when its done..what are the specific tools i need to do this?
thanx everyone in advanced.......
Old Aug 8, 2008 | 04:53 AM
eighty9crx's Avatar
Default Re: seat pan swap, need of help immediately!!! (lunalink)
What year ef do you have cause it doesn't mention anything? You will need a pair of hog ring pliers for crimping the rings that hold the uphoulstery to the seat pan and as for removing them maybe the same tool can be used but not to sure. Use a couple pair of strong needle nose pliers like from snap-on and pull the hog rings off. You will have to use the seat pans for your exact car. 1988 Crx seat pans and rails are completely different from the 1989 to 1990.
Old Aug 8, 2008 | 05:27 AM
crx_si-r's Avatar
Default Re: seat pan swap, need of help immediately!!! (eighty9crx)
the tools i used were:
- 10mm (for seat rails)
- 17 mm or 19mm dont remember which one (for the bolt located on the side by the seatbelt)
- 12mm for the side bracket that allows you to adjust the seat angle
- needle nose pliers to remove the metal clips
- oh and i also used some carpet/upholstery adhesive to help the pan stick to the new foam
thats about it. its a pretty straight forward process. only thing is that the seats from a HB are different, pan wise. the way the pan bolts up to the back of the seat is located inward compared to crx seat pans.
Old Aug 9, 2008 | 01:16 AM
lunalink's Avatar
Default Re: seat pan swap, need of help immediately!!! (crx_si-r)
OK KOOL..BUT I DECIDED TO DO IT THE LAZY WAY...I JUST CUT THE BRACKET THAT HELD THE PAN TO THE BACKREST AND BOLTED IT TO THE CRX RAILS AND IT FITS PERFECT...JUST HAD TO ADD A NUT ON THE OTHER SIDE OF THE BOLT SINCE THE INTEGRA PAN DOESNT HAVE THREADS IN IT..BUT THANKS FOR THE ADVISE..ILL USE THAT WHEN I RE-UPHOSTER THE ORIGINAL SEATS...MY CRX IS A DX BY THE WAY...
quirarte626
May 6, 2009 08:40 PM
BLU CIVIC
Dec 29, 2008 02:56 PM
xalents23
Nov 18, 2008 04:19 PM
B1TEM3
16
Jan 19, 2006 08:27 PM
0ptimus prime
Jul 26, 2005 08:39 AM
