Throttle body coolant lines...
Old Jul 29, 2008 | 03:22 PM
EFstyle's Avatar
Default Throttle body coolant lines...
First question... what does this valve do on the bottom of the throttle body?
Second question... is it a good idea to bypass this and go stright to the IACV with the coolant lines to keep throttle body temps down?
Old Jul 29, 2008 | 06:28 PM
Crx Jimmy's Avatar
Default Re: Throttle body coolant lines... (EFstyle)
I bypassed it, if its being tuned you can alter the iavc duty cycle so it idles fine, the obd2 throttle body's dont have the fitv on the bottom they just have the hose go in then out. the only time I would recommend leaving it on is if it gets super cold where you live, so if you dont live in canada you should be fine
Old Jul 29, 2008 | 06:40 PM
Dc4iNtEgRa's Avatar
Is Partying at your House
Default Re: Throttle body coolant lines... (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">I bypassed it, if its being tuned you can alter the iavc duty cycle so it idles fine, the obd2 throttle body's dont have the fitv on the bottom they just have the hose go in then out. the only time I would recommend leaving it on is if it gets super cold where you live, so if you dont live in canada you should be fine</TD></TR></TABLE>
So, is it possible for it to idle fine with a obd-2 TB while converted obd-1?
ls_bitik
Jan 4, 2008 03:31 PM
bricks2k4civic
Oct 31, 2005 08:56 PM
99ctr
Oct 5, 2005 12:23 PM
4DRmafia
Sep 3, 2005 10:17 AM
mini-cRx
Mar 24, 2004 09:18 AM
