d16z6 swap into 1997 civic DX
can i driectly sawp the z6 into the dx. im going to convert from obd2 to obd1 with a jumper harness, but i want to know how do i connect the vtec so it works. It looks like the jumper harness from rywire doesn't have a vtec subharness in the jumper. What are all the other things that i would need to make the swap work besides the edu and the distubitor?
just get an ex harness...if you dont want to or cant find one then you just have to run the extra 3 wires for vtec and the ones for the knock sensor(google for the wire locations). and you have to do somthing about the injectors...either get some obd-2 injectors or change the plugs on the harness to obd-1 plugs. either way is fine
Cozmikk
Sep 21, 2017 12:33 AM
Cozmikk
Sep 19, 2017 05:07 AM
Valo
14
Sep 29, 2011 01:43 PM
