Need what kind of head gasket for?
Old Jul 29, 2008 | 01:35 PM
boostn97's Avatar
Default Need what kind of head gasket for?
I just bought a 97 hatch with a b16 block fully built sleeved, and it has a gsr head with everything u can do to it, it has a t3/t4 turbo pushing 19 lbs of boost i need a head gasket what kind should i go with?
Old Jul 29, 2008 | 03:08 PM
superfast666's Avatar
Default Re: Need what kind of head gasket for? (boostn97)
it might be smart to actually know a thing or 2 about what you buy before you buy it know one is gonna be able to tell you what gasket if you never mentioned what the bore size is hopefully you know what a bore size is
Old Jul 29, 2008 | 04:26 PM
boostn97's Avatar
84mm
Old Jul 29, 2008 | 07:41 PM
what is everything you can do to a head
Old Aug 1, 2008 | 06:53 PM
NitrousWhore's Avatar
Default Re: Need what kind of head gasket for? (superfast666)
While were on this subject I have a question also.
Any advise on a b16a2 head b18c1 block that may or may not see nitrous? and could bump my compression up a bit?
Old Aug 1, 2008 | 06:57 PM
nicks-eg6's Avatar
Default Re: Need what kind of head gasket for? (NitrousWhore)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NitrousWhore &raquo;</TD></TR><TR><TD CLASS="quote">While were on this subject I have a question also.
Any advise on a b16a2 head b18c1 block that may or may not see nitrous? and could bump my compression up a bit?</TD></TR></TABLE>
that's basically a poorman's type-r... what shot are going to run, if you decide to run nitrous...
Old Aug 1, 2008 | 07:20 PM
95dxsir2's Avatar
b16 and b18c are the same bore i believe.
just get a b16 84mm head gasket, what is on it now?
http://asian_e.tripod.com/Honda_Engine_Specs.htm
measure the thickness on it
Nick_Cartwright
Apr 4, 2013 08:55 AM
poormans_typer69
Oct 10, 2006 02:55 PM
GetSTROKED
Aug 8, 2006 05:17 PM
greasemonkee
Oct 13, 2005 10:57 AM
99RedSi
12
Mar 10, 2005 10:34 AM
