WTT H2D EF
i got a 90 ef with a built h2d everything will go with car all you need is a resistor box and a dizzy cap and it will start again my cap cracked and my resistor box took a **** on me motor made 233hp and 178lbs or torque on a dynojet car car ran 12.2 on drag radial i was spinning pretty good i had my fun with it now its time for someone else to have fun. IM LOOKING FOR A DSM AWD TURBO, MKIII TURBO SUPRA, TURBO 240SX, TURBO RX7, TURBO MR2, TURBO HONDA LMK WHAT YOU GOT OPEN TO EVERYTHING PRETTY MUCH
h22 motor legit w/ papers
new balance shaft eliminaters
new t-belt and water pump
new bisimoto plate kit
new bisimoto motor mount
new aem fuel rail
new camp1320 header
new dh-racing custom intake manifold
new rywire harness
micro polished h23 crank
new eagle h23 rods
modified oversized type s pistons 87.5mm
type s cams
new arp head studs
crx si trans fresh rebuild
carbon coated synchros 2nd 3rd 4th
quaif lsd unit
centerforce clutch
edt traction bars
half radiator setup
hondata s200 w/ boost option
half dash setup
si cluster setup
also have 2 h22a4 block
1 h22 head
1 new set of oversized type s pistons
1 h23 crank
1 f23 crank
new aem fuel rail
new camp1320 header
new rywire harness
new eagle h23 rods
type s cams
new arp head studs
quaif lsd unit
centerforce clutch
edt traction bars
half radiator setup
half dash setup
si cluster setup
1 h22 head
1 h23 crank
1 f23 crank
