DA hub swap! theses are my aligment readings...am i ok?
Old Jul 29, 2008 | 12:24 PM
dannysolis92005's Avatar
Default DA hub swap! theses are my aligment readings...am i ok?
<U>FRONT</U>
toe: .20
L: .10
R: .10
Camber:.5
L: -0.5
R: -1.0
Caster:.8
L: 3.1
R: 2.3
my looks slightly opened, i will see how if i get any tire wear! thanks,
Old Jul 29, 2008 | 01:04 PM
Tyson's Avatar
Default Re: DA hub swap! theses are my aligment readings...am i ok? (dannysolis92005)
your toe is horrible.
get it fixed.
how did you get readings without getting it fixed?
Old Jul 30, 2008 | 09:50 AM
Default Re: DA hub swap! theses are my aligment readings...am i ok? (Tyson)
really, i did get a "pro" alignment at a shop. what reading should i expect?
Old Jul 30, 2008 | 10:08 AM
Tyson's Avatar
nevermind. its fine. i was thinking in the wrong units. im assuming thats degrees you posted now.
degrees = inches X 2.3 for a 25" diameter wheel.
front toe specs are +/- .118in = .27degrees
Old Jul 30, 2008 | 11:32 AM
it is degrees. so im of by like .07 so i should be good then...thanks a lot, ill post if any bad uneven tire wear. thanks alot!
Johnny Gdq
Honda CR-V & Element
Feb 28, 2019 07:30 AM
Johnny Gdq
Sep 4, 2018 12:31 AM
Low and no vtec
Aug 28, 2013 09:40 PM
Justin Jones
Mar 17, 2008 11:58 AM
solo-x
Nov 21, 2002 09:26 AM
