EG interchangeable suspension question
Old Jul 29, 2008 | 08:41 AM
tadashisan's Avatar
Default EG interchangeable suspension question
there any suspension parts from other honda/acura cars that'll swap right into the eg? such as struts, springs..etc
Old Jul 29, 2008 | 08:46 AM
EGhatchguy's Avatar
Default Re: EG interchangeable suspension question (tadashisan)
struts from a 94-01 integra will be direct bolt in for 5th gens i know because i just bought skunk2 struts for an integra for my 95 si. springs also are interchangeable but the spring rates are stiffer on the integras
Old Jul 29, 2008 | 08:49 AM
tadashisan's Avatar
Default Re: EG interchangeable suspension question (EGhatchguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGhatchguy &raquo;</TD></TR><TR><TD CLASS="quote">struts from a 94-01 integra will be direct bolt in for 5th gens i know because i just bought skunk2 struts for an integra for my 95 si. springs also are interchangeable but the spring rates are stiffer on the integras</TD></TR></TABLE>
nice thanks
Hanmin's Avatar
every suspension between the civic and integra and interchangeable. Including the delsol and crx. For the front suspension you just have to use the right fork. So if you were using crx suspensions on an eg, you gotta use the crx fork. And for the back, its all the same, except for the crx and type r. The crx and type r have different LCA. So if you wanted to put the back crx suspension on the eg, you gotta take the lca too.
93_db2
Suspension & Brakes
10
Apr 23, 2006 09:58 AM
yj
May 16, 2004 05:48 PM
EH..phantom
Mar 14, 2004 10:21 AM
