Advice needed: Fuel Filter
Old Jul 28, 2008 | 11:03 PM
keeblar's Avatar
Default Advice needed: Fuel Filter
Hey guys I wanted to know if I could get some Advice on changing out a fuel filter...
I have a 91 crx Si and wanted to know some tips...
Some people have told me after the fuel filter is removed and I am getting ready to change the new one on.. That I should put a little gas inside the new Fuel filter before installing it back on so it does not mess up...
Is this true???
Or
Should I just take off the old one and bolt back on the new one ??? ( without the Fuel inside the new filter)
Thanks guys
Old Jul 29, 2008 | 12:33 AM
keeblar's Avatar
Default Re: Advice needed: Fuel Filter (keeblar)
anybody please!
Old Jul 29, 2008 | 03:14 AM
schueytenten's Avatar
never filled it with fuel. never had any problems.
Old Jul 29, 2008 | 06:29 AM
kirbyman's Avatar
Default Re: Advice needed: Fuel Filter (schueytenten)
^ X2
Old Jul 29, 2008 | 08:03 AM
keeblar's Avatar
Default Re: Advice needed: Fuel Filter (kirbyman)
kk thanks for some info...
Old Jul 29, 2008 | 04:22 PM
beige89civic's Avatar
* B A N N E D *
Cycle the ignition key and the fuel pump will fill it up. make sure you install all metal washers to prevent leaks.
Old Jul 29, 2008 | 06:22 PM
Crx Jimmy's Avatar
Default Re: Advice needed: Fuel Filter (beige89civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beige89civic &raquo;</TD></TR><TR><TD CLASS="quote">Cycle the ignition key and the fuel pump will fill it up. make sure you install all metal washers to prevent leaks.</TD></TR></TABLE>
X2^^ you dont need to fill it. just cycle the key 10 times or so, you can actually hear the air coming out and returning to the tank
Old Jul 29, 2008 | 10:53 PM
spikehead221's Avatar
From: Staring down the barrell of my 12 ga. Texas, USA
Default Re: Advice needed: Fuel Filter (Crx Jimmy)
^^^^^^^X3^^^^^^^^^^^^^
Old Jul 30, 2008 | 07:52 AM
Hondaisok's Avatar
Just replace it and start the car and check for leaks! That's what I did both times I have replaced them.
cmwalker
Jul 12, 2012 12:10 AM
B18B EK
Sep 7, 2008 08:16 AM
TMC_EF
Mar 22, 2007 01:07 PM
WayneGro
Oct 24, 2003 04:58 AM
Muckman
Dec 9, 2002 01:09 PM
