ABS plugs?
You know... I have not looked on my car, but if it's anything like other mechanical systems, its triggers of a serated hub ring at the hub. Being 08 our cars may have an integrated traction control/abs system that is related to throttle position. My car is so new I have not crossed that bridge as yet. what are you looking for at the sensor?
no im not trying to disconnect the ABS sensors if i wanted a deathwish i would, but im looking to get some brembo brakes, or hell any kind of bigger brakes for the front so i was just thinking about were the ABS sensors might be located? it kinda just popped up into my head.
The sensor reads magnetically, off a toothed wheel at the outer CV joint in front, & under the hub in back.
When you get big brakes, you will probably not have to disturb the sensors.
If you're looking for where to unplug the wires for the sensors, Honda usually runs the wires into the engine compartment, or into the trunk, before the first plug where you can disconnect it.
murphmatic
Honda Civic (2001 - 2005)
Aug 27, 2014 02:09 PM
josh-roy
Jul 30, 2010 02:32 AM
