where can i get pistons for a bored out f22b
Old Jul 28, 2008 | 10:16 PM
wyldechild86's Avatar
Default where can i get pistons for a bored out f22b
is there a websit i can go to or who can i get oversized pistons for a honda from
Old Jul 29, 2008 | 12:00 AM
fubuallstar's Avatar
Default Re: where can i get pistons for a bored out f22b (wyldechild86)
search!!!!!!!!!!! TOP RIGHT CORNER OF PAGE MIGHT BE IN RED
Old Jul 29, 2008 | 03:10 AM
GhostAccord's Avatar
Check out this link Click Here. You should be able to find everything your looking for on that site. If you can't find it on there. Contact them and I'm sure they can let you know were to get it. The customer service I received when I sent an email was quick and very informative.
Old Jul 29, 2008 | 04:52 AM
JDM_DC4_Fanatic's Avatar
Default Re: where can i get pistons for a bored out f22b (GhostAccord)
crower will also have parts for it. You just need to use H22 bottom end parts.
http://www.crower.com
Old Jul 29, 2008 | 04:56 AM
Default Re: where can i get pistons for a bored out f22b (JDM_DC4_Fanatic)
Do not de-stroke your F with H22 parts. I think you meant to say H23 parts Crower has them listed as H23/F22. The Honda part numbers for the H23 and F22 crank and rods are the same. So that means that one isn't any better than the other.
Modified by GhostAccord at 10:05 AM 7/29/2008
Old Jul 29, 2008 | 05:14 AM
my typo, thanks for the correction.
Old Jul 29, 2008 | 05:22 AM
NP.
OP.... H pistons aren't the best fit for the F's either. The compression hight is a wee bit to much. Well, it's only 1mm more but that is quite a bit when you consider that our F pistons are already .002 out of the hole to begin with. I have read that a few people that have over sized bores are running the K20/24 pistons. They have the same 30mm Comp Ht. I will be trying out a set of Wiseco 89mm K20/24 pistons in my build.
Bangher4$
Feb 16, 2009 11:15 AM
kasso
May 21, 2007 08:10 PM
dk4ever
Dec 7, 2006 06:56 AM
H23A1LUDE
Mar 3, 2003 07:38 AM
