LOTS of H series tranny parts and random b stuff CHEAP
Old Jul 28, 2008 | 08:35 PM
extralargenog's Avatar
Default LOTS of H series tranny parts and random b stuff CHEAP
have a bunch of random crap kicking around in my garage I want to get rid of.... LMK if you are interested. ALl of the tranny stuff I have listed is in good shape, I finally got around to sifting through alll my collection of broken crap..... SO if you need any H tranny stuff.. Let me know.
Feel free to lowball....
1 red anodized APC H22 sparkplug cover
MINGT BRAND NEW EG/DC brake master cylinder
D series dizzy body ( no internals )
H series:
Prelude IACV
1 M2F4 case with slight damage around end case axle seal area... case is complete
3 sets of shifter forks known to not be bent
2 Reverse Idler shaft/gear/shifter sets
A variety of good syncro rings and springs....
2 each - 3rd and fifth gearsets that are good
Roller bearings and collars
2 Differential and final drive ring gears (OEM non LSD)
Top shifter box linkage assy.
1 M2F4 gear cluster with all good gears . 1 messed up selector, and 1 messed up syncro ring... Gears are all good, as is the input shaft
1 M2Y4 Gearcluster with a broke 2nd and fourth gearset (unfortunately making the input shaft unusable too, but EVERYTHING else is mint (syncros, selectors, final drive shaft... etc)... SHifted perfectly fine..
I could put 1 perfectly good gearset out of it with good geasrs and syncros and everything, or you can....
Case beasrings, and a variety of 3 and 5 sets that are in good shape
H series throwout fork
H/F sewries tranny cable bracket
F series thermostat housing w/ waterneck
B series inside upper timing cover
B series DS motormount
H series Oil pump pickup
PARADOX_sf
Jan 15, 2014 08:02 PM
93egboosted
Nov 7, 2013 08:45 AM
Romo Pyro
Apr 14, 2009 11:50 AM
boostnls
Jun 30, 2004 09:12 PM
GahDamnGsr
Sep 3, 2003 11:54 AM
