bb6 SiR front bumper on a USDM prelude
im about to order a SiR front clip tomorrow simply for the bumper, fenders, lights, marker lights, & hood w/ bonnet. basically i want the parts simply because i have front end damage, im NOT going for a RHD conversion
can anybody tell me without a shadow of a doubt that the JDM parts im buying are stricly bolt on minus the marker lights. i might have to order some new hardware but thats not that big of a problem
also im sorry i have never been that successful at removing fenders, all of that and such. is it easy to remove and install/align everything? all i heard so far was the hood was hard...
also what will it take to install the marker lights?
FYI i was TOLD that it was stricly bolt-on. im figuring that should be true
yes they are interchangeable as far as mounting it.. i dont know why you would need to align anything as long as your frame is straight and true, they are OEM so they should fit perfectly if they aren't damaged. The hood is pretty straight forward, just make sure you get your windshieldwasher's out before you take out the nuts. other than that.. its a very straight forward job, probably a good idea to have a friend or two around to hold things up. the fender's most annoying bolt is the one where the doors close onto, but shouldn't be a problem with the proper extensions. good luck
Jonnyr4c
31
Nov 20, 2005 04:28 PM
speedlimitR
23
May 9, 2002 09:23 PM
