4th Gen ABS Code 41, what is it, how do I fix it.
Hello, my car blinked out 4 flashes, paused and then one more flash on the ABS light when I jumped the connection; I assumed this was a code 41. If it is 41, what does that mean and how is it fixed?
Thanks in advance.
Modified by caliskier at 10:36 AM 7/29/2008
Thanks in advance.
I was surfing around last night and found a site that gave codes for Honda, did not describe which models. It was saying it was the Right wheel sensor? Dose that seam right? Is there a "prelude" ABS code page somewhere?
Thanks again.
Thanks again.
Well, maybe I will be able to help other people… I was surfing around again today at lunch and found this:
https://www.spoonhonda.com/Sea...t=119
Pretty sweet, Helms manuals for hondas
Downloaded the manual and had to go to the 1992 version to read up on brakes, there wasn’t info on the other years. I assume that means that the brake system was not changed through the years, I have a 1995.
Manual is pretty straight forward, talks about 4WS which the 95 does not have. Has anyone troubleshot a Speed Sensor before? If so any advice would be helpful, are they hard to get to?
Modified by caliskier at 11:04 AM 7/29/2008
