new tim/belt now a code 9
Old Jul 21, 2002 | 04:05 PM
tdc's Avatar
tdc
Default new tim/belt now a code 9
i put a new timing belt in my zc and now i get a code 9
(code 9 #1 cyl ) but my timing marks seem to be on it run but will not idle .. i need some info on timimg marks and just to be sure the #1 cyl is on the driver side right? on my timing marks both ups are in the best i can get up and the 2 timing marks are in the middle of the 2 up marks and they shoulde line up on a goofy ange right? anyone see what i doing wrong here or am i forgetting somthing
Old Jul 21, 2002 | 07:42 PM
tdc's Avatar
tdc
Default Re: new tim/belt now a code 9 (tdc)
what nothing come on guys ... i`ve checked and checked the timing marks and their on the cams but asfore the #1 cyl should the piston be right on tdc or just before tdc .. come on some has to have somthing here
Old Jul 21, 2002 | 07:53 PM
USDM 4G VTEC's Avatar
did u make sure the crank was aligned also.????
if it trows a code 9 it comes from the CYL sensor on the dizzy....
i got that code on my mini me and i cant get it to be fixed...
Old Jul 21, 2002 | 07:54 PM
Bgladfelter's Avatar
ok, so you've got the crank pulley at TDC and then the cams to their setting with the 2 dashes on each lining up with the head right?
If so, reset your ECU (pull Hazard fuse for 10-15 sec).
If its still going nuts, you may have a genuine prob.
Thats the sensor that is on the other cam across from the dist.
Per Helms (UK version for ZC specifically) test the resistance between the 2 prongs on the sensor. If between 700-1K its fine, if not replace it.
HTH
tautog
Apr 2, 2017 01:51 PM
Bh8teen
Aug 31, 2005 09:26 PM
civic_dork
Jul 3, 2005 07:40 AM
red civic standard
Jul 14, 2002 07:25 PM
