92 EX Auto not starting?
Old Jul 28, 2008 | 12:05 PM
4npower's Avatar
Default 92 EX Auto not starting?
I got a 92 ex auto, It has been acting up over the last few days. It starts sometimes with no issue. Other times it turns over and over with nothing. And finally the best. Put key in and turn it to the start pos and the check engine light comes on and the (D) light flashes ? ? ? Turn off pull key out sometimes it comes back on and sometimes it go's off and the car starts?
PLEASE HELP.
Old Jul 29, 2008 | 11:58 AM
4npower's Avatar
Default Re: 92 EX Auto not starting? (4npower)
PLEASE NE ONE HELP ! ! ! ! ! ! ! ! ! ! ! !
Old Jul 29, 2008 | 02:31 PM
mavvrik's Avatar
Codes tell all bro.
If your check engine light is coming on than your car is trying to tell you that something is wrong. Vehicles communicate via codes--so if you can get the code that would tell you exactly what causing all your problems.
A vehicle having troubles starting and a check engine light could be many things. Could be a bad 02, a bad starter, a bad dizzy, anything. Get the code, get your answer.
Old Jul 30, 2008 | 01:04 PM
4npower's Avatar
Default Re: (mavvrik)
Thanks. However when the lights on the car will not start and i have no way of getting it to a tech to pull the codes.
Old Jul 30, 2008 | 01:36 PM
mavvrik's Avatar
Sounds like it could most likely be a spark problem. Bad coil maybe. You might just want to take it in to a mechanic for a diagnostic. That would be your best bet
Old Jul 30, 2008 | 03:44 PM
biz90accord's Avatar
i would say check your main relay, i have a 90 accord lx that had the same problem, your main relay will stick and cut off power to your fuel pump thats why the starter will crank but wont turn over cuz no fuel, if i gave it a few minutes the main relay would get unstuck adn start but that is only good sometime, sometime i had to hit the relay until it didint work no more and had to buy a new one, so i would say to try the main relay it under the dash on the drivers side behind the cruise control module
Old Jul 30, 2008 | 08:48 PM
bseriescrxsi's Avatar
Default Re: 92 EX Auto not starting? (biz90accord)
unstuck?.......thats a new one.....technically it cant get stuck seeing as the connections are soldered to the board.....its bad connections that make a main relay fail
AudioFunk
Jul 29, 2013 11:02 AM
benwadb1
Jun 28, 2008 05:50 PM
j95civic
Aug 1, 2007 02:20 PM
mhng
Apr 23, 2005 06:44 AM
slicksno
Nov 5, 2004 12:57 PM
