Brake Lights stuck on on, Help
Old Jul 28, 2008 | 11:42 AM
guero2craze's Avatar
Default Brake Lights stuck on on, Help
As the title says, my integra's Brake lights are ON even when the car is not on or when noone is pressing on the brake pedal and the switch for the lights is on off and the handbrake is not engaged
This problem just started today, and I dont kno where to start looking...I tried to disconnect the fuse on the brake lights but couldnt find it...for right now the battery on the car is disconnected
Just need some advice where to look or what to look for? Any info would help at this moment. Thanks
Old Jul 28, 2008 | 12:25 PM
prime_suspect's Avatar
Default Re: Brake Lights stuck on on, Help (guero2craze)
I had this problem not too long ago and found that the silicone piece on my brake pedal that pressed the brake light switch had broken off. Basically, I bought a bolt and some washers and rigged up another one. Problem solved.
Old Jul 28, 2008 | 05:30 PM
herewegoagain's Avatar
if they are stuck on, i would replace the brake light switch. you could unplug it and see if they go out. its a switch on the brake pedal about 3 inches long. the plug should have 4 wires going to it. rectangular plug. unplug and see if they go out.
brndnhlcmb
May 1, 2010 08:44 PM
gsrsuperman
13
Jul 21, 2008 10:20 AM
PREACHERBREW
May 20, 2008 02:09 PM
88crxhfb16
11
Jul 28, 2005 08:07 PM
CONLESS
Jun 15, 2005 09:48 PM
