fixed my broken rt4wd civic wagon tranny
Old Jul 28, 2008 | 10:45 AM
mattcivic's Avatar
Default fixed my broken rt4wd civic wagon tranny
I had 2 4wd trannies 1 was blown and the other had a broken bell housing from an accident the car it was in got into. so i cut out the part of the blown tranny and welded it into the good tranny.
cut out the part i needed and robbed the tranfer case and shifter
shaved the piece till it fit bolted the piece and tranny to a spare motor as a jig and welded it together and WA LA! spare tranny baby
Old Jul 28, 2008 | 11:15 AM
GTibunny16v's Avatar
Default Re: fixed my broken rt4wd civic wagon tranny (mattcivic)
Why didnt you just disassemble the good one and put the pieces in the good case?
Old Jul 28, 2008 | 01:38 PM
cpl rampage's Avatar
Default Re: fixed my broken rt4wd civic wagon tranny (GTibunny16v)
I belive both cases were bad, one has the bell housing cracked at the front, and the other blew the gears/bearing area that connects to the transfer case. so he cut the section from the blown tranny, and welded it to the bell housing on the good tranny.
Old Jul 28, 2008 | 05:05 PM
raiden571's Avatar
get r done. hopefully it didnt warp it out of wack and make the tranny sit cockeyed on the block
Old Jul 28, 2008 | 07:27 PM
mattcivic's Avatar
Default Re: fixed my broken rt4wd civic wagon tranny (cpl rampage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cpl rampage &raquo;</TD></TR><TR><TD CLASS="quote">I belive both cases were bad, one has the bell housing cracked at the front, and the other blew the gears/bearing area that connects to the transfer case. so he cut the section from the blown tranny, and welded it to the bell housing on the good tranny.</TD></TR></TABLE>
yep
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raiden571 &raquo;</TD></TR><TR><TD CLASS="quote">get r done. hopefully it didnt warp it out of wack and make the tranny sit cockeyed on the block</TD></TR></TABLE>
it works i tested it out bolted right back up to the motor just fine.
Old Jul 28, 2008 | 08:17 PM
Good stuff. I spy a Snap On impact gun. Best tool Ive ever bought. I have the newer version though with the magnesium nose.
Old Jul 28, 2008 | 11:08 PM
mattcivic's Avatar
Ya the new on is bad *** but mine does all i want someday when it takes a dump i will upgrade. its so nice changing wheels in my driveway or at the track is a breeze with it. frineds laughed at me when i first got it but now they want to borrow it.
Old Jul 29, 2008 | 05:26 AM
JDM_DC4_Fanatic's Avatar
I just picked up the HO mag one. Love the thing. But your right, everyone called me crazy for spending soo much on it, but they all want to use it on their cars at home, lol. Since i bought it, I rarely use my IR 2135 titanium
Old Jul 29, 2008 | 06:51 AM
Default Re: fixed my broken rt4wd civic wagon tranny (JDM_DC4_Fanatic)
Its definitely money well spent. Only time I pull out an air powered impact gun is when I need my 3/4" unit for stubborn crank bolts.
Old Jul 31, 2008 | 01:58 PM
RC000E's Avatar
You don't have an extra transfer case do you? Or even an extra transfer case housing?
Old Aug 4, 2008 | 02:10 PM
pgpbubble's Avatar
Default Re: fixed my broken rt4wd civic wagon tranny (RC000E)
i &lt;3 my mg31 3/8 impact, theres not much this thing cant take off, and it so cheap
Old Aug 4, 2008 | 02:42 PM
comp's Avatar
Default Re: fixed my broken rt4wd civic wagon tranny (pgpbubble)
what are those out of ??
Old Aug 4, 2008 | 06:34 PM
mattcivic's Avatar
Default Re: fixed my broken rt4wd civic wagon tranny (comp)
88-91 rt4wd civic wagons
Old Aug 4, 2008 | 06:54 PM
LoSt is BlaCk's Avatar
hey, i'm not sure if i read this right, but i'm hoping that maybe you have another good transfer case i could buy off you...actually what parts are left over?
Old Aug 7, 2008 | 12:19 PM
TigWiz's Avatar
Default Re: fixed my broken rt4wd civic wagon tranny (LoSt is BlaCk)
Nice fix! I've seen similar repairs made before, but dont remember exactly what caused the failure in the first place.
redboost10
Jan 14, 2007 02:35 PM
92CiviC4dr
Jan 18, 2006 01:49 PM
