interchange able throttle body pulley
got the skunk2 intake manifold for gsr i got the itr cable and bracket. now i all i need is the non-gsr throttle pulley.. would an LS pulley work on the intake manifold. and would the gsr pulley be able to work on the ls throttle body. any help would be good.
Modified by vtecGsr420 at 8:53 AM 7/30/2008
i used my ls pulley on my gsr Throttle body. (be sure to take pictures) on my skunk2 manifold.
and i dont kno what chu mean by.."would the gsr pulley be able to work on the ls manifold"
also is this for a DA?
You should try to get a B16 throttle pulley if you want to run your throttle cable from that direction. The LS one is larger and opens less with the same amount of pedal travel.
